Poping Fuses In Amp
I own a directed 1200t and it calls for 3 30a fuses. its wired at 1 ohm bridged. And once i turn it up to certin point and it pops the fuses like nuthin'.
could this be cuz i dont have any inline fuse off the battery?
Subs - Diamond d6 12's
Box - Prefab Memphis newer style
Amp - Directed 1200t
Car - 98 Honda Accord LX f23a1
yes and you should deff have a fuse off the batt it will save your amp from frying, are you sure there are no shorts in the wiring for the amp??
I'm Deffently positive i installed it this morning. and i spent prolly 10 dollars in fuses just to bump today and be safe. if i have the same problem when i put an 200a fuse off the battery would it be safe to use higher amp fuses in my amp?
Actually the fuses in the amp protect it from frying, the fuse on the power wire protects the wire/vehicle in case there is a short in the wire somewhere. I wold suggest getting an inline fuse asap! but yes your power wire may be shorting out somewhere causing your amps fuses to blow.
Scientia est Vox
SMD SUPER BUYER/SELLER
I'm went over all wireing and coulden't figure it out i was just gonna get like 40a fuses for the amp.
someone also told me about fuses called slow blows that are ment for heat idk if hes just bullshit'n...
ne1?
what size power wire are you running?
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
ne1?
slowblows? i think bullshit ive never heard but maybe its just me
slowblows hmmm heard of em but not for amplifiers and if your amp is getting hot your thermal protect should kick in b4 your fuses pop... hopefully!
Scientia est Vox
  • Who's Online   0 Members, 0 Anonymous, 1469 Guests (See full list)
