So, I have been wanting to swing other ways in car and home audio that seems like alot of people are not going, atleast to make money.
I was decided to start doing component systems, and home audio set ups. Now, Home audio is my love, nothing better than staying home to watch some bad ass action movie with a lot of Boom, and sound effects.
So, a person here on SMD asked if I could build them a component set, well get one together. So we discussed what they really wanted from a sound system, picked out some mids, and tweeters
This will be 2- Selenium mids, and 1 Vifa silk dome tweeter, similar set up posted, but the drivers haven't arrived yet.
This is going for a flat quality sound, not to boomy, or to piercing.
The crossover design, based on the mids and tweeters seem to be best crossed over at 2700hz 12db
Luckily this was a easy build due to the mids and tweeters being 4ohms (dual 8ohm mids ran at 4ohm)
I used a little bit of acrylic, rhino lined Masonite for the pc board, and a black ABS backing- I tried to make it look good for the budget in mind
Came out nice so far, I still have to glue down the components, work with the wiring. All connections are soldered nice and very low resistance components
heres some pics, and there will be more to come
This is just a 12db butterworth crossover
looks sweet man!
I have some little changes to do to them, see how this is in 3 layers, and where the components are, seems like its to tall, and the bottom layer is to close, and bends a little bit? well, I'am using the spacers differently so it looks better, will get rid of that bent bottom ABS plastic
Iam listening to techno right now on Satalite radio, and these with missmatched mids and tweeters sounds VERY good
what I'am using now is 3ohms of mids, and 6 ohm tweeters, the crossover was designed for 4ohm all the way around
time to get a beer
and chill
damn.. when i have some money, i needa hit you up for some custom home audio speakers..
Hustle hard, Stack paper,
It's alright, ya'll haters,
It's nothing, We major,
You see me, Hi Hater! =)
~ Manio
This particular build is for Logans truck, but Iam getting some really nice mids, and highs, pretty much like SEAS, but cheaper
I plan on doing a home setup eventually with those- major dipole design,
WMTMW
Meaning, top and bottom large woofers, 8" or 10", then working inward, mids, 6.5", and then a horn silk dome tweeter
These will be about 6ft high, and meant for pure clarity
Logan, Iam gonna change the cross overs a bit, instead of using screws, Iam going to change it over to colored speaker wire out.. .I may do that tonite
It will be easier to match tweeters/mids up to the crossovers, and I will do some female connectors in and out
