I have been reading and reading many threads on this and other audio sites. But I'm confused when people describe their setups and mention multiple runs of O gauge. I have always ran from the battery to a distrabution block to the amps. Can someone shed some light on this for me.
If you look at the wire you have it has a lot of little strands of wire. That is basically what the multiple runs of wire is doing, lots of little(OK, 1/0 is huge but its the same principle) wires making up one big one, usually connecting to multiple batteries for more power!!
Basically they mean instead of running just one wire from battery to back, they run MULTIPLE. Once you get to high power applications, it's a neccessity to have tons of 1/0 wire or bigger.
Need an install? Hit me up.
[email protected]
Its like the batt sitting next to the amp when you do multi runs for better çurent and power flow
Dont forget to match the runs of power with as many runs of ground
yes absolutely, 1 run of 0 awg is really only good for 3k rms. ppl with muti amps and need to feed each amp individually or 2 inputs on a amp. muti runs will let more power flow, same as the multi grounds will find the path of least resistances also.
ok, say i have 2 1/0 runs for +. I was talking to Randy and he said i should pry do a run to chassis ground and then bring it up with the big three. and then a full run for 2 - runs. well. would having 2 chassis grounds a one - run to bat be benifitial?
Bills
KwB
Team DC Audio Midwest captain
Bills
yeah that would be a good idea. when i had my blazer i did that i gronded in the real and up front with the big 3. i only had the rear ground for a whileand finally did a 2 ground run and found that my batts charged .4v higher was charging 14.3v went to 14.6v steady. i did a resistance check with clamp meter and it was showed a pretty big difference. the less resistance the better of course so muti grounds are gonna help
o, hey man, long time no talk. haha, hows it going? didn't reconize your stuff with the diff avatar. haha
Bills
KwB
  • Who's Online   0 Members, 0 Anonymous, 2560 Guests (See full list)
