Come on guys I need more oppinions on both setups. I want to good and the bad. $700 is alot to spend on a pair of subs and make the wrong choice.
Vehicle: 2001 Ford Escape
Head Unit: Kenwood Kdc-x592
All out for a rebuild.
New shit coming in the next 30 days.
Im aiming for crazy spl. I realy like the bls but Iv heard bad things about the tinsile leads breaking becouse there not woven. Has any one had a problem with this. I love the way the rl-ps are built but Im not sure if there going to be loud enuff for me. Keep it in mind that I had 4 8" l7s before this build.
theres no longer a tinsil slap issue they are wocen between the spiders now
If there is no issue with the tinsel slap I think Im going to go with the fis. Ill just have to get an rlp for the house when I get situated in alaska. I still want to know how much difference would there be in spl between the two. Are we talkin bl slightly louder or hella louder?
Fis FTW. Im guessing my saz-1500d should be sufficient power for them. Or should I upgrade to a 3000d or such. Acording to chris at db-r.com he said sundown is supposidly coming out with a 2000d soon. IDK well see.
Thanks for all the input man. Ima get the subs here build the enclosure and eventualy upgrade to the saz-3000d. My last question is for two bl18s and a saz-3000d should I double panel my box or is it not necessary. I will be building a wall in the back of my escape and forward firing the subs.
I knew double baffle and a shit load of internal bracing where in order. Ill just double layer everything, 45 all my corners and glass the inside. What is the best way to keep the double baffles together? Just alot of drywall/wood screws?
