What's the best stuff to recone a speaker from like home depot ?
Scott told me to use plastic fusion but I don't like how the foam surround is setting
Whatcha guys got?
I use engine RTV gasket glue for the surrounds and dome (as long as its foam surrounds), clamp it down, and wait over night
for the spider most people here will tell you CA- its fast.....
When I worked at the speaker shop, this is what we used, and there is no breaking this stuff away, and that is the only draw back- reconing again, you need to use a really straight hard flat blade to break away the epoxy
http://www.servcorponline.com/3m-scotchwel...p420-b3420.html
Edited by Forevrbumpn
at my friends shop he use's super thick CA glue made for model's. he has never had a problem.
----reference's----
meade916
ok, this is my question now...... how do you clamp the whole suround unless you have like 30 clamps. haha. or is 4 going to work fine as long as it is held close to the basket and is given enough time to set and seal.
Bills
KwB
Team DC Audio Midwest captain
^^^ exactly, cut a ring or 2, and mount subwoofer upside down while it dries
the weight of the motor is perfect for getting that glue bead down flat, and perfect
ok, sweet. so sorry for thread jacking this Alpine. haha.
so all you do when you recone is get old cone out, then when everything is removed form old surround, spider, and tinsle lead, you put the new cone in/on, clue surround, glue dust cap, glue spider, and then solder the tinsle leads?
Bills
KwB
pretty much
1) tear down
2) clean all glue surfaces where surround and spiders lay flat
3) clean motor gap usually with a coffee stir stick and some double sided tape wrapped around it- possible some acetone to clean up burned coil debris
4) shim coil with proper shim, not toilet paper roll... lol
5) lay down glue for spider, and surround, mount re cone kit
- clamp spider with either waxed MDF rings- 2 piece, and flip woofer upside down so the surround can dry
solder when dried
test, then dome
