Bumpindemlowzz Posted December 2, 2008 Report Posted December 2, 2008 I have a s10 with stock electrical system. What all do you think i should to do power a Sundown SAZ-1500D amp? I was just thinking a couple powermaster batteries. I noticed that powermaster has 16 volt batteries. Will that mess everything up getting those cause i have no idea going about this build. Btw im getting a 18" Fi BL Subwoofer fully loaded. 2010 Silverado 18" DC XL 18 DC 2k XS Power Batts
droopy89 Posted December 2, 2008 Report Posted December 2, 2008 U have the same set up as me, but i have the RT T10001, which is a bit harder on the electrical, i have a 250 amp alt. and two kinetik batts. and i still have a bit of voltage drop,, and if it gonna be your daily driver, i wouldnt go to a 16 volt setup 1997 S10 EC Whats in it 106.9 Sq.ft. Hushmat DB Elec. 250 amp alt. HC800&HC1400 MLA Module Alpine 9886 Knukonceptz wires Clarion EQS746 poopy Alpine door co-ax's Change IS Coming
ChevyBoy Posted December 2, 2008 Report Posted December 2, 2008 U have the same set up as me, but i have the RT T10001, which is a bit harder on the electrical, i have a 250 amp alt. and two kinetik batts. and i still have a bit of voltage drop,, and if it gonna be your daily driver, i wouldnt go to a 16 volt setupsomething is SERIOUSLY wrong with your set up if you have voltage drop with that alt/batt set up. (unless youre at idle and idle sucks on that alt??)
Bumpindemlowzz Posted December 2, 2008 Author Report Posted December 2, 2008 How would i set up my ride to accept the 16 volt batt? I dont want it to ruin anything. I cant just slap it in and expect it to be all good can i? Also how would it effect the amplifier? U have the same set up as me, but i have the RT T10001, which is a bit harder on the electrical, i have a 250 amp alt. and two kinetik batts. and i still have a bit of voltage drop,, and if it gonna be your daily driver, i wouldnt go to a 16 volt setup 2010 Silverado 18" DC XL 18 DC 2k XS Power Batts
Bumpindemlowzz Posted December 2, 2008 Author Report Posted December 2, 2008 Im sorry my bad i thought you said to go with the 16 volt setup... Do i have to have a ho alt? How would i set up my ride to accept the 16 volt batt? I dont want it to ruin anything. I cant just slap it in and expect it to be all good can i? Also how would it effect the amplifier? 2010 Silverado 18" DC XL 18 DC 2k XS Power Batts
Team Sundown's Charles Posted December 2, 2008 Report Posted December 2, 2008 I have a kicker 1500.1 and the only thing I did was a big 3 and add a kinetick 800. I have problem what so every. Just a battery and see how your voltage is before you go out and spend money on things you don't need. 1993 Mazda Mx-3 Subs: 2 18" DC Audio Lvl 4 D.7 Highs amp: Sundown SAX-100.4 Sub amp: Sundown SAZ-3000D Electrical:Kinetik 1200 under hood, 2-Kinetik 2400 rear All 1/0 KnuKonceptz Wire Power/Ground, Big 3, 8Ga Speaker Wire, KnuKonceptz Karma RCA's Dampening: 120sqft 80Mil Thick Sound Destroyer Mat Goal: 150 DB 149.9 Street Bass
droopy89 Posted December 2, 2008 Report Posted December 2, 2008 something is SERIOUSLY wrong with your set up if you have voltage drop with that alt/batt set up. (unless youre at idle and idle sucks on that alt??) my idle does kinda suck EDIT: but i was talking about volt. drop at idle, at revs, no problems at all 1997 S10 EC Whats in it 106.9 Sq.ft. Hushmat DB Elec. 250 amp alt. HC800&HC1400 MLA Module Alpine 9886 Knukonceptz wires Clarion EQS746 poopy Alpine door co-ax's Change IS Coming
ChevyBoy Posted December 2, 2008 Report Posted December 2, 2008 my idle does kinda suck EDIT: but i was talking about volt. drop at idle, at revs, no problems at all yea i was gonna say u had a short somewhere or something lol
Boon Posted December 2, 2008 Report Posted December 2, 2008 The rule with 16v seems to be that if you have to ask, you can't run it. Going to 16v can be pretty complicated. 10.x volts fo' life!
