seanbw94708 Posted December 3, 2008 Report Posted December 3, 2008 i have... A 33w 16h 18.5d space for an enclosure a 1995 accord coupe a sundown 1500 for power i listen to classic rock and rap. i have approximately a $500 budget for two woofers. spl is my goal, but i do not want a fart box. i want loud low music nothing more. couple of woofers i was thinking about: IA DR 12d1 fi Q d1 *** trash d1 PAP WMD 12d1 (they're so cheap!) im running a RE sx 15d2 that has been reconed by fi with some cooling (pole plug) and suspension upgrades. it gets down but i want to squeeze as much as i can out of that space. two twelves have about the same displacement as a 15 but would the added motor force give me more bass? i'm open to suggestions on woofers and box designs, what port size, length and orientation. ZAP!!
Nightshade Posted December 3, 2008 Report Posted December 3, 2008 Out of the woofers that you listed I'd say that the Q's or the *** woofers would do best for your application. If it were me I'd do 2 of the Q's in the largest box that you can fit in your car. They are well know for playing the low notes really well. I don't think that your going to get better low end response out of a single 15 unless you went with something that is ment to play extremely low like a btl or LMS Ultra. Those woofers are a bit expensive but with a 15 you will more than likely have to fire the woofer up at the trunk lid or at an angle. With 2 12's you can fire the woofers foward and the ports to the side and get a ton more spl than it would be possible with a 15. 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
