Your mean Watts Divided by Voltage,
I did a rough calculation and got this
2000w @ 14.4V Will Draw 138.88A @ 1ohm
1000w @ 14.4V Will Draw 69.4A @ 2 Ohms
good rough numbers for an example. But only true in a prefect world with a 100% efficient amp.
Most good amps will be 80-90% efficient, tops. then you measure your voltage drop when playing.
So if an 85% efficient amp does 2000w on a 14.4v source that drops to 13.8v (example).
It would have to draw about 175A or so. (not exact, done in my head)
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
Efficiency of an amp plummets as you load it down.
An amp at 1 ohm will draw lots more than twice the current it does at 2 ohms, assuming it makes twice the output power at 1 ohm.
10.x volts fo' life!
boon=100% correct
go by wattage for a rough estimate of draw if you know your voltage, the resistance doesnt really matter as far as computing draw, but it will drop your effeciency...ive seen alot of amps do like 95%effecient@8ohm and 65%effecient@1ohm, to give you an idea of the difference
Team DC
boon=100% correct
i see. thats nice to know.
thanks for the replies
forgot about the law, so that means resistance doesn't matter?
in this case you go by at what the wattage no mater the resistance...if its putting out 400 watts at 1 ohm or 400 watts at 4 ohm doesnt matter what ohm laod its putting out that much power
NoFearX18 said:
trainman0978 said:
  • Who's Online   0 Members, 0 Anonymous, 2766 Guests (See full list)
