What will work best.
11 members have voted
  1. 1. box terminals
    • Brass-Threaded Rod
      3
    • Stainless-Threaded Rod
      5
    • Drill a little hole and then seal her up
      3
silicone... i lube that rod up before i insert it into the mdf hole.... haha :girl_devil:
just keep it off the brass... and if u do make a mess... use sandpaper to scuff the brass back to clean
haha now im confused.. so now its stainless steel rod/bolts with brass nuts and washers. cant wait to get my wood and get started. but might be slightly delayed but I already feel better after going to the f-that thread in this forum :)
thx all
Loudness is no substitute for musicianship, and partial deafness is no badge of honor. I was once able to hear this advice.
Build Log>>>
http://www.stevemeadedesigns.com/board/ind...pid=672024&
New Build
Believe in the order
:spiteful:
Wasted, Incorporated
Up Front: Optima Yellowtop
HU:Pioneer Avic N1 w/ 2007 upgrade
Front Stage: MB Quart 6.5 comps
Rear Fill: Infinity Reference
Sub Stage: RE MT 18
Sub Amp: Undecided
Sub Enclosure: 5.5 cubes tuned to 33hz
Absolute Terminals
SkyTec 5100RS 2-Way LCD Pager
KnuKonceptz Wire
My Build Log
:spiteful:
good idea with the backing plate ...you wont mind if I borrow that idea hahaha ;) did you counter sunk that plate or did it pull in when you tighened it?
looks like an 10 mm bolt ?
Build Log>>>
New Build
not entirely true.
the bolts I use have 0/ zero resistance, im not losing anything.
actually you are just cause you have 0 resistance doesnt meant your flow is the same as straight wire.
im talking in terms of surface area, tere is not way a 1/4 inch bolt has the surface area of 8 guage wire.....
like i said i use bolts as well but the BEST way is a direct connection to the amp...
99 4runner
walled 2 18 fi btl ufo psi recones 15 cubes 33hz port bottom behind the C pillar
orion hcca 8000.1d
8 Polk audio mm 691 6x9
2 2000x4 hifonics
320 amp singer alt
3 g31
1 baby seat 1 booster seat and daily driven!
Actually, i sell them. they arent copyrighted. as i told someone else, if you cant think of something more original on your own, be my guest ;)
Sub Stage: RE MT 18
Sub Amp: Undecided
Absolute Terminals
KnuKonceptz Wire
My Build Log
actually, there not too far off. if thats the case, use 5/16 or 3/8
great ill get somone in china to start mass producing them in a sweat shop.. jk jk but seriosly I doubt shipping them to Singapore would be worth it .
you have any box building skills? cos no one wants to check my tuning for me; I posted in the speakerbox section.
gave specks the works but no response. problem is no one over here knows either cos they all play sealed boxes
Build Log>>>
New Build
  • Who's Online   0 Members, 0 Anonymous, 916 Guests (See full list)
