Bat cap, reason why is cuz they charge, and sicharge super fast, no need to worry about charging issues. Its like buying a Cap, but a lot higher Farads- Bat, and Alt later man, wait for something to come out for that car first
i was on batcap.net for a while and it seems simple to install. on their site it says to always fuse a power source. obviously i have a fuse going from the battery to the batcap, but do i need a fuse going from the batcap to the amp?
it would be recommended to fuse bat cap to amp. always fuse after a battery.
that's extra protection ..... having a fuse between the batcap and amp. as stated on the diagram. we all know to fuse after the underhood battery and then be sure to fuse before the batcap also since it somewhat works like a battery. now if you'd like to fuse after the batcap then by all means go ahead.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
that was a major problem at the audio shop about running an extra ground from the front to batcap. most shops said to just stick with the OK diagram. but as it shows the batcap is grounded to the amp and that's impossible because a amp only has one ground. now you could use the same grounding point as the amp. but we all know capacitors and amps should be grounded separately. regardless i have still heard good things about the batcap.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
