What wires do you use do you have to run the power directly to the battery or is there something i can tap into? and any good led sites you can give me would be great, because i cant find anything good local. thanks
I use the fuse panel inside the car. usually under the steering wheel (or close to) and pull the power from there to power my LEDs
do you think you can give me a site where i can find this thing, cuz i think i have that adapter but my led's wire is wayyyyyyyy too small, and any good led sites?
What do you mean? You find a switched power source in your fuse box, plug the wires to it so it only turns on when your cars on or however you want it wired, no adapter need lol.
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
does every car have a switched power source in the fuse box and if so what does it look like? I meant that i have this fuse powered thing that plugs into the fuse and turns it into a 18 guage wire so you can run the power.
I would just wire it to constant and throw a toggle in there for all your leds...
Passport Build Here
Alarm: Prestige APS997A 2-Way/Remote Start
HeadUnit: Pioneer DEH-P6000UB
Front Battery: Yellowtop Optima D34/78
Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH
Subs: 2x DC Lv4XL 18's
Amps: 2x Sundown Saz1500's Strapped
Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube)
Pillars: AudioBahn AS31Q
Front Doors: Clif Designs TX40.5
Back Doors: Clif Designs CD50.4C
Rear Speakers: Clif Designs TX46.5
Front/Rear Amp: Kicker ZX350.4
Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4)
Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter
Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
Yeah, get yourself a test light, turn your car off, find fuses that don't have power to them, turn your car on and see if it then has power. If you find one that is off when your keys off and on when your keys on then walla you have yourself a switched power source. I don't use adapters, I do it the ghetto way, remove the fuse, insert wire, re insert fuse lol.
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
cool thanks man
use the wiper fuse
DC.jpgDC POWER
  • Who's Online   0 Members, 0 Anonymous, 1597 Guests (See full list)
