loburbon Posted December 8, 2008 Report Posted December 8, 2008 9515's are rated at 1500rms, but they really come to life with 2500+ daily. a dd m3 per sub works great 2000 gmc yukon 4 sundown Zv3 15's 4 dd m2a's kenwood kdc-x994 2 batcap 4000's 1 batcap 2000 dual alts. 154@37hz and climbing http://www.cardomain.com/ride/3231683 http://www.myspace.com/torque150
uhoh_45 Posted December 8, 2008 Author Report Posted December 8, 2008 as for amp im not sure yet im looking into the GP 3000D-Pro and there will be a second baffle on the outside of the box going into the cab and im thinking bout building a steel rack on the outside of the box and putting diamond plating on the outside of that to keep the box in seein as how he doesnt want to put a tono (Sp) cover on R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
Pitbullx Posted December 8, 2008 Report Posted December 8, 2008 9515's are rated at 1500rms, but they really come to life with 2500+ daily. a dd m3 per sub works great1500w rms per coil Team Devastation Mixed Martial ArtsMachado Brazilian JiujitsuOnce I lock it on there's no escape I don't train to make you tap, I train to tear your arm, leg, or head off. Its your job to tap before I can do that -Pain is only weakness leaving the body, its kill or be killed and only the strong survive...Rockford FosgateDigital DesignsFi Car AudioCrossfire Car Audio
Pitbullx Posted December 8, 2008 Report Posted December 8, 2008 as for amp im not sure yet im looking into the GP 3000D-Pro and there will be a second baffle on the outside of the box going into the cab and im thinking bout building a steel rack on the outside of the box and putting diamond plating on the outside of that to keep the box in seein as how he doesnt want to put a tono (Sp) cover on guess he doesnt plan on keeping his subs very long Team Devastation Mixed Martial ArtsMachado Brazilian JiujitsuOnce I lock it on there's no escape I don't train to make you tap, I train to tear your arm, leg, or head off. Its your job to tap before I can do that -Pain is only weakness leaving the body, its kill or be killed and only the strong survive...Rockford FosgateDigital DesignsFi Car AudioCrossfire Car Audio
loburbon Posted December 8, 2008 Report Posted December 8, 2008 lmfao http://www.stevemeadedesigns.com/board/public/style_emoticons/default/01nocomment8so.giflaugh if you want but i've been using these subs for years and had teachers like steve from dd, and my good friends mike jones, bobby stephens and several others to teach me bout these subs and box designs. why dont you call dd and ask them bout putting them in a 3cube net box and ask them if it will be as loud and low. 2000 gmc yukon 4 sundown Zv3 15's 4 dd m2a's kenwood kdc-x994 2 batcap 4000's 1 batcap 2000 dual alts. 154@37hz and climbing http://www.cardomain.com/ride/3231683 http://www.myspace.com/torque150
loburbon Posted December 8, 2008 Report Posted December 8, 2008 1500w rms per coil now thats one hell of an idea. a m3 @ .5ohm daily puts out [email protected] you can keep up the voltage. 2000 gmc yukon 4 sundown Zv3 15's 4 dd m2a's kenwood kdc-x994 2 batcap 4000's 1 batcap 2000 dual alts. 154@37hz and climbing http://www.cardomain.com/ride/3231683 http://www.myspace.com/torque150
uhoh_45 Posted December 8, 2008 Author Report Posted December 8, 2008 guess he doesnt plan on keeping his subs very long explain? R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
Pitbullx Posted December 8, 2008 Report Posted December 8, 2008 laugh if you want but i've been using these subs for years and had teachers like steve from dd, and my good friends mike jones, bobby stephens and several others to teach me bout these subs and box designs. why dont you call dd and ask them bout putting them in a 3cube net box and ask them if it will be as loud and low. Ive been running DD's since late 99 early 00, without counting I have 15-20 DD subs in my room of different series and models. I know what has worked well in daily and spl applications and I know what hasnt worked (in my applications). And good for you being friends with Mike Jones, hes the man, hes helped me out bigtime when I was in a bind in the past... thas my nigga and as far as asking someone about putting them in a 3cube box and getting their opinion, Im cool on that... Ive done it before in the past and wasnt disappointed with the results... stop coat tailing, sac riding, and name dropping... its lame Team Devastation Mixed Martial ArtsMachado Brazilian JiujitsuOnce I lock it on there's no escape I don't train to make you tap, I train to tear your arm, leg, or head off. Its your job to tap before I can do that -Pain is only weakness leaving the body, its kill or be killed and only the strong survive...Rockford FosgateDigital DesignsFi Car AudioCrossfire Car Audio
Pitbullx Posted December 8, 2008 Report Posted December 8, 2008 explain?subs and box just chillin in the bed of a truck screams "steal me" Team Devastation Mixed Martial ArtsMachado Brazilian JiujitsuOnce I lock it on there's no escape I don't train to make you tap, I train to tear your arm, leg, or head off. Its your job to tap before I can do that -Pain is only weakness leaving the body, its kill or be killed and only the strong survive...Rockford FosgateDigital DesignsFi Car AudioCrossfire Car Audio
loburbon Posted December 8, 2008 Report Posted December 8, 2008 Ive been running DD's since late 99 early 00, without counting I have 15-20 DD subs in my room of different series and models. I know what has worked well in daily and spl applications and I know what hasnt worked (in my applications). And good for you being friends with Mike Jones, hes the man, hes helped me out bigtime when I was in a bind in the past... thas my nigga and as far as asking someone about putting them in a 3cube box and getting their opinion, Im cool on that... Ive done it before in the past and wasnt disappointed with the results... stop coat tailing, sac riding, and name dropping... its lame well good for you for having small boxes work, and the only reason names were brought up is because of your lame ass no comment post. and maybe you have lower expectations then i do. cause i have done small box setups and its just not impressive. if you've ran dd's then you know how they sound in the proper box. as for coat tailing, sac riding, and name dropping......get over it i was merely stating who help teach me on boxes. so your saying if meade helped you learn some and you said his name that it would be name dropping and sac riding......i think not. 2000 gmc yukon 4 sundown Zv3 15's 4 dd m2a's kenwood kdc-x994 2 batcap 4000's 1 batcap 2000 dual alts. 154@37hz and climbing http://www.cardomain.com/ride/3231683 http://www.myspace.com/torque150
