uhoh_45 Posted December 8, 2008 Report Posted December 8, 2008 its for 2 9515s in a blowthrough in buddy's truck box is roughly 7 cubes 112^2 of port tuned to 34hz all opinions are welcome R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
Bigg Boy Posted December 8, 2008 Report Posted December 8, 2008 only thing i have to say is 45's Dodge Magnum with custom 300c front end, laid out on air bags *4) 12" Cadence Daytona walled *1) AudioQue 20k *270a DC Power Alt (Dual coming soon)
loburbon Posted December 8, 2008 Report Posted December 8, 2008 that box is way to small for 2 9515's. to get the sound out of those subs you need at least 5cuft per sub with 15sqin of port per cube. 2000 gmc yukon 4 sundown Zv3 15's 4 dd m2a's kenwood kdc-x994 2 batcap 4000's 1 batcap 2000 dual alts. 154@37hz and climbing http://www.cardomain.com/ride/3231683 http://www.myspace.com/torque150
uhoh_45 Posted December 8, 2008 Author Report Posted December 8, 2008 really on there website it said 3.5-4 cubes per sub if im not mistaken R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
loburbon Posted December 8, 2008 Report Posted December 8, 2008 rec box for a 9515 is 4.25 after sub and port, but thats for a 40hz daily box. i'm a dd dealer and i talk to steve and jassa at dd weekly, you can doubt me on dd subs if you want. i had 2 9515's in my explore and the box 12cuft gross and it was tuned to 35hz and i did a 151.3. 2000 gmc yukon 4 sundown Zv3 15's 4 dd m2a's kenwood kdc-x994 2 batcap 4000's 1 batcap 2000 dual alts. 154@37hz and climbing http://www.cardomain.com/ride/3231683 http://www.myspace.com/torque150
uhoh_45 Posted December 8, 2008 Author Report Posted December 8, 2008 no i dont doubt you i just donno if i'll be able to get 10-11 cubes and keep half the bed still... thanks for the help R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
Pitbullx Posted December 8, 2008 Report Posted December 8, 2008 they will work in a box as small as 3cubes net per sub 4-5cubes is louder but 3 is okay for daily usage..... what amp(s)? also that box needs alot more bracing and I recommend a double baffle..... Team Devastation Mixed Martial ArtsMachado Brazilian JiujitsuOnce I lock it on there's no escape I don't train to make you tap, I train to tear your arm, leg, or head off. Its your job to tap before I can do that -Pain is only weakness leaving the body, its kill or be killed and only the strong survive...Rockford FosgateDigital DesignsFi Car AudioCrossfire Car Audio
loburbon Posted December 8, 2008 Report Posted December 8, 2008 3 cubes wont get as loud or low, but yes it will work. 3 cubes would be awsome tuned high in a burp machine. dd's dont like small boxes or small ports 2000 gmc yukon 4 sundown Zv3 15's 4 dd m2a's kenwood kdc-x994 2 batcap 4000's 1 batcap 2000 dual alts. 154@37hz and climbing http://www.cardomain.com/ride/3231683 http://www.myspace.com/torque150
Eskii Posted December 8, 2008 Report Posted December 8, 2008 I'd put those subs in a larger box, how much power is being run to them? Previous: 1988 Nissan Patrol Rockford T800.4 Rockford T1 15 (sealed) Rockford 6.5 Components Current: 1997 Jeep Wrangler Build goals... 1x RF P300.2 4x Hertz HCX165's Built Completes Alpine 9886 Headunit RF P300.2 RF P500-1bd 2x RF P2-D2 8" Subs, 1.3 cubes @39.5Hz 4x Hertz HCX130's Current comment... Satisfied for the moment, focusing on performance upgrades
Pitbullx Posted December 8, 2008 Report Posted December 8, 2008 3 cubes wont get as loud or low, but yes it will work. 3 cubes would be awsome tuned high in a burp machine. dd's dont like small boxes or small portslmfao http://www.stevemeadedesigns.com/board/public/style_emoticons/default/01nocomment8so.gif Team Devastation Mixed Martial ArtsMachado Brazilian JiujitsuOnce I lock it on there's no escape I don't train to make you tap, I train to tear your arm, leg, or head off. Its your job to tap before I can do that -Pain is only weakness leaving the body, its kill or be killed and only the strong survive...Rockford FosgateDigital DesignsFi Car AudioCrossfire Car Audio
