Guest Fi-Beat-Down Posted December 8, 2008 Report Posted December 8, 2008 Well i just hand a random question, Does other people use anything that I don't have already more so to improve or monitor there set up. I have. Sub woofer fi bl 10" 4 after market highs speakers 4 tweeters hc 1800 battery amp 1600 watt,.. the regular stuff, I dont have a voltage gauge that i senn in some of your guys rides, the lcd ones, idk if I need one of them. I have not done the big 3 upgrade idk if i should... any input would be great just to know..
Torres Posted December 8, 2008 Report Posted December 8, 2008 i say always do the big 3 upgrade. always. i believe it will help the all around voltage of the car too even if you dont have an audio system in it. but anything 500-1000 watts+ i'd definitely do it
RamenNoodles Posted December 8, 2008 Report Posted December 8, 2008 DO the big 3. And the voltage gauge always helps man, I will never be without mine anymore. Diablo Audio Technologies Fi Car Audio Ascendant Audio
Guest Fi-Beat-Down Posted December 8, 2008 Report Posted December 8, 2008 i say always do the big 3 upgrade. always. i believe it will help the all around voltage of the car too even if you dont have an audio system in it. but anything 500-1000 watts+ i'd definitely do it yeah i do be leave you now that im think about it, just for the fact of being able to transfer power quicker and not short out anything... i do think may alternator was stinking today like it was getting hot, i didn't hear belts squeal, idk i need to do it.. to re cap the steps, and yeah i seen the post of how its done,.. but do i take a wire for the alternators power to the power on the battery, with a fuse block? but idk what size fuse ??? ground from the battery to the firewall i have like a show string wire, as of now, its a eclipse.. so it has thin wires. and ground on the chassis to the motor somewhere solid ? let me know. please and thank you.
Guest Fi-Beat-Down Posted December 8, 2008 Report Posted December 8, 2008 DO the big 3. And the voltage gauge always helps man, I will never be without mine anymore. ok well i seen the small square lcd ones online for like 15 bucks, but this will be dumb to ask how do i go about hooking it up to get the best feed back.
RamenNoodles Posted December 8, 2008 Report Posted December 8, 2008 Alternator to battery (+) Battery (-) to engine block (-) Battery (-) to chassis (-) The fuse is not necessary. Some people have it and some people dont. I personally do not but thats just me. Fuse it about 18" away from the battery post. And depending on what your amp pulls, go a little higher then that. If it pulls 120 amps for example, go with a 150 amp fuse. Diablo Audio Technologies Fi Car Audio Ascendant Audio
RamenNoodles Posted December 8, 2008 Report Posted December 8, 2008 ok well i seen the small square lcd ones online for like 15 bucks, but this will be dumb to ask how do i go about hooking it up to get the best feed back. I use the square Stinger voltage gauge from Darvex.com. Its a great product and an ease to install. Basically you will need to wire a positive wire, a ground wire and a remote wire. I have mine wired to my heaunit so that when my headunit powers on, the gauge will accordingly as well. You will need some more wire to extend the length of it because they only give you about a foot on each pos, neg, and rem. Diablo Audio Technologies Fi Car Audio Ascendant Audio
Guest Fi-Beat-Down Posted December 8, 2008 Report Posted December 8, 2008 Alternator to battery (+)Battery (-) to engine block (-) Battery (-) to chassis (-) The fuse is not necessary. Some people have it and some people dont. I personally do not but thats just me. Fuse it about 18" away from the battery post. And depending on what your amp pulls, go a little higher then that. If it pulls 120 amps for example, go with a 150 amp fuse. My stock alt, is 75 amps, lol i will def try and do this to night, will i notice a difference off the bat you think? like being able to hit deeper notes? or anything?
Guest Fi-Beat-Down Posted December 8, 2008 Report Posted December 8, 2008 I use the square Stinger voltage gauge from Darvex.com. Its a great product and an ease to install.Basically you will need to wire a positive wire, a ground wire and a remote wire. I have mine wired to my heaunit so that when my headunit powers on, the gauge will accordingly as well. You will need some more wire to extend the length of it because they only give you about a foot on each pos, neg, and rem. awesome well yeah I looked on that web site and I will order one in a few mins, plus they take paypal. are they easy to mount, .. like is my only choice to use is 2 sided tape ? how did you mount it cleanly looking.
