Woofer Wiring With 4 Inputs
After talking with my brother, he doesn't seem to believe that I am able to achieve a 1 ohm load with the subs I have.
I have (4) Dual 2 ohm subs.
Here is a pic of the inputs on my amp..
Every woofer wiring wizard I have seen shows only 1 ohm for 2 wire inputs. My amp has 4 inputs. I have an Atomic 5000.1. Would I be able to achieve a 1 ohm load with this setup?
Hummer H2
(8) Crossfire XS V2 15's
(4) Crescendo Audio BC 5500s
(16) Crescendo 6.5's, (16) Crescendo Tweeters, (4) Beyma 8" Midrange
http://www.youtube.com/Owners1
http://www.the12volt.com/caraudio/woofer_c...sp?Q=4&I=22
Just use one set of speaker inputs.
Or wire up each pair of subs to 2 ohms like in the second pic down here:
http://www.the12volt.com/caraudio/woofer_c...sp?Q=2&I=22
and put each pair in it's own set of inputs.
The inputs on the amp are internally linked ++ -- , it just makes it easier to hook subs up.
Check out StoneSounds to see my recent builds.Or look at the Flying White Facebook Page!
i wouldn't use no less than 8 ga for the speaker wire.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   0 Members, 0 Anonymous, 929 Guests (See full list)
