Crump Posted December 12, 2008 Report Posted December 12, 2008 I will be running the power wire to a 10 Farad Rockford Cap, from there a RF T-1500 1 channel, and a RF T-400 4 channel, what amp fuse do i need? And also do i need a fuse for one of the 3 wires in the big 3? i have heard different things. Thanks Team gg Team doa Installs I have doneMy 2010 Rebuild 144 db so far....2 DC xl 10s Firing into cabin on a RF 25002 12" AQ HD's powered by a Saz 2k + Lots o Mids+Highs
dmanson Posted December 12, 2008 Report Posted December 12, 2008 I will be running the power wire to a 10 Farad Rockford Cap, from there a RF T-1500 1 channel, and a RF T-400 4 channel, what amp fuse do i need? And also do i need a fuse for one of the 3 wires in the big 3? i have heard different things. Thanks i'd do a run of 1/0 with no less than a 250 amp fuse. as for big 3 read up in the electrical section .............. you should only be fusing the wire from the front battery to the amp(s). 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
eliassami5 Posted December 18, 2008 Report Posted December 18, 2008 i'd do a run of 1/0 with no less than a 250 amp fuse. as for big 3 read up in the electrical section .............. you should only be fusing the wire from the front battery to the amp(s). If you bypass the fuse box when running your + cable from the battery to the alternator then yes you need a fuse on that wire, if you go from the alt>fuse box>battery then you dont need a fuse on that wire. 91' Jeep Cherokee - The Heep Just Empty Every Pocket 96' Volvo 960 - The B◘x [sPL_4_U] HiFonics - Alpine Pioneer - Clarion Infinity - Kicker KnuKonceptz
