Custom Subwoofer Now For Sale..pg 4
awesome mang, love seeing how this is coming along, looks like some beefy parts going into it, what kinda power are you gonna feed it? should be b/a man
'98 Dodge Durango 5.9L
5% front windows, 2.5% on all backs
Alpine CDA-9883
Kicker ZX350.4
Kicker KS650's in all doors
Kicker 1/0 hyperflex
I've always wanted to do this I had two motors off some 15's and held on to them for like a year wanting to do something but never did and tosted them now I kinda wish I kept them :(. Lookin good though
Not sure yet, as far as right now, I don't have much of a power system in my Denali, I plan on buying a Sundown 1200 at least after Christmas.
But this sub is going up for sale after I beat on it, make sure there is nothing wrong, and that it can handle some abuse
I'am assembling 50% of this with---- CA. I usually use epoxy, but The epoxy is a couple weeks out on order. I will use the black rubber CA, the thick CA, and some other epoxy I use for emergency sub repair.
Almost done.... made my spider clamp. I should have just waited for the epoxy... I still don't CA even after seeing how easy it can be to use.
Pics comming shortly
can you share the site where you ordered the parts from spider/coil and the like. i have a few motors and baskets laying around too.
----reference's----
meade916
Posted Image
This is Foamed PVC, looked like some pretty descent stuff to start with
Posted Image
had to do some exacting cuts, little trick to keep everything in place is to use spray adhesive to one side and a sheet of mdf on the baskside the the PVC material doesn't move while your cutting it
Posted Image
I added some 0.75" alum spacers instead of cutting the former height down 0.75". I really want the former down low, so I can use these inverted aluminum domes I have, only prob is, I need the former to stick up no more than 3/8" inch
Posted Image
bottom bead
Posted Image
top bead
Posted Image
Posted Image
close up look of the spider clamp
Posted Image
still debating whether to solder the leads to the terminals, or to use ring terminals to the terminals- My solder iron tip sucks, so I may have to crimp it
:mellow:
So, I just need to do the ring terminals, and solder the leads to the coil, Epoxy the top, and glue the dome, and off for testing
Maybe, but then I'd have to kill you
:diablo:
Well, there are a few companies, alot are over seas, what Iam doing is since I have a few "hook ups" here in the US, they are getting me the parts, and I am assembling them
Trust me, its so much harder to get proper parts than most think- A spider, coil, and cone- If you want things done right, you need to know things like spider compliance, gauge thickness of coil, windings, how long to order the tinned leads on a coil, OD and ID of spiders, cup spider, or flat, or progressive spider, height of the cone from mounting to coil opening, weight.
Lots of factors
Well, for this, Iam gonna pound it hard first (un domed) to make sure the spider pack is glued down properly, then if all is good, I will dome it, and sell it
If I do get it sold, maybe $200 range, parts along cost me about half that
more-more ... Kepp up the good work man.
May I ask you regarding the bedliner ..? how ruff is it and do u need to use a primer with it? ...also do you have any idea how it compares to flectone.. planning to use it on wood if that will make any differece.
Loudness is no substitute for musicianship, and partial deafness is no badge of honor. I was once able to hear this advice.
Build Log>>>
http://www.stevemeadedesigns.com/board/ind...pid=672024&
New Build
Believe in the order
