javy101 Posted December 13, 2008 Report Posted December 13, 2008 ight guys so im finally going to go to a comp dis weekend but just wanted to get a little advice before i go (it will be my first time to go). i have a fi btl 18" 08 model and a sundown 3000d. i have never got metered before so i have know clue where my speaker is peakin. my box is 7.5cuft tuned to 32hz. what do you guys recommend for my burp frequency. (just somewhere to start)
Noobtastic14 Posted December 13, 2008 Report Posted December 13, 2008 location? and are you doing dbdrag or bass race/street beat? -Drew I am a United States Military Arts and Crafts Professional. Sand it off, Paint it on. uhoh_45 said: dont be a pussy P give the jeep to drew
javy101 Posted December 13, 2008 Author Report Posted December 13, 2008 im in fort worth texas it going to be USACi i think i will be in the stock 601-1800
Decaf Posted December 13, 2008 Report Posted December 13, 2008 ask them to play a sweep from 30-40hz... then 40-50hz... at ~half volume this should give u a good starting point since u are tuned so low with a large box u likely wont peak over 40hz but ur car will dictate that what kinda suv
javy101 Posted December 13, 2008 Author Report Posted December 13, 2008 O its in a Truck a ford 150 extended cab with seats out
javy101 Posted December 13, 2008 Author Report Posted December 13, 2008 so do they give you a cd i thought you brought your own
Boon Posted December 13, 2008 Report Posted December 13, 2008 Play a sweep as mentioned above. If it's a termlab and they're nice you can pull up the numerical data to get your exact peak. If you're tuned at 32hz then your box probably peaks in the car about 6hz or so above that. Because your cabin is quite small you might get lucky and having a resonance node of your box peak within the frequency limit (is it 80hz in USACI? It is in dbdrag...) - if you have a peak at 35hz try it at 70hz as well. 10.x volts fo' life!
alvitae Posted December 13, 2008 Report Posted December 13, 2008 The usaci I went to let you borrow a cd, Then they told me to put it on track 19. It's a sine sweep. That was my first run. the second run they told me to turn it to track 57, that was the hertz I hit best on the sweep. Went real smooth and gave me my best number possible at that particular time I think.
