Okay...so here is tha story.
I just currently installed my 360.2, took my stock deck out to do the OEM integration wiring...My stock H/U got wet from a sudden downpoor and fried the output curcuit when i plugged it in. SO, I called my cousin who has the EXACT same vehicle as mine and changed his stock deck to a aftermarket one. He Sent his H/U to me and I thought it would be as easy as plug and play. I was wrong!! The unit is locked because the VINs of the two different trucks....Is there anyway I can get this fixed WITHOUT goin to the dealer? VIA a code or something? It sucks because I JUST got everything in and I cant even hear it. Ihave SOME music via the aux. port and Ipod on the 360.2... BUT I cant use ALL the tuning feat. Please HELP!
Kaimana
aka
smokeumtires
you need a tech2. i think your going to have to take it to the dealer.
you can cook bacon shirtless if you're not a pussy...lol
not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be.
DC.jpgDC POWER
http://www.toolhawker.com/GM-Tech-2-Basic-...item_40631.html
some shops other than the dealer have it. When i was in high school our auto shop had one.
DC.jpgDC POWER
if you have the code is should work... unless its different with domestic vehicles..
Hustle hard, Stack paper,
It's alright, ya'll haters,
It's nothing, We major,
You see me, Hi Hater! =)
~ Manio
i was that way up untill about 99
DC.jpgDC POWER
sounds like you have a 03 up chevy, if so you need a tech 2 or a part called gmon by periphal electronics
i have 1 if needed, 65.00 plus shipping..
I would just go t a dealer if i was you.
your cousin would probally have to go to a dealer to get the code since the radio is linked to the vin number of his truck once you get the code you can connect it in your truck and put in the code and it should work.they might charge a fee to do it also.
  • Who's Online   1 Member, 0 Anonymous, 493 Guests (See full list)
