00cex Posted December 15, 2008 Report Posted December 15, 2008 Hello I have a '99 Ford Explorer Eddie Bauer edition and was wondering is there some way I can keep the steering wheel controls for the audio. I.E. can I have the volume up volume down and "next" controls. Thanks for your time, Mark. New: 1998 Chevy Blazer 4.3L 2dr Alt: Unsure yet Headunit: Kenwood Excelon KDC-X494 Subs: 2) 15" Hifonics Olympus V.2's Amps: 2) Hifonics Goliath GX3000's European Version Maxx-link
audiofanaticz Posted December 15, 2008 Report Posted December 15, 2008 Hello I have a '99 Ford Explorer Eddie Bauer edition and was wondering is there some way I can keep the steering wheel controls for the audio. I.E. can I have the volume up volume down and "next" controls. Thanks for your time, Mark. yes you can, you need to buy the harness in most cases, and you MUST have a aftermarked headunit that will allow the use of the external controls. Thats about the best answer you can get without more info on your headunit you are running or going to run.
audiofanaticz Posted December 15, 2008 Report Posted December 15, 2008 The additional info needed is: 2 door or 4 door? Mach audio system? Premium audio system? Stock audio system? Aftermarket radio planned on being used.. The adapters are around $60+ to use the steering wheel controls, and no you cant chop the wires, and make it work without having to spend the money on the harness. You can use this link and it will tell you the needed harness needed since you didnt specify all your info. Some harness will work with pioneer, sony and jensen headunits only, while others will work with Alpines, but like i said before, you need a compatible headunit. http://www.crutchfield.com/cgi-bin/autoinf...tml%3ftp%3d3405 Here are a few harness it maybe, but I cant give you a 100% answer which one you need without the above needed info. http://www.crutchfield.com/S-xS3V53Nn44M/p...PAC-SWI-PS.html http://www.crutchfield.com/p_127SWIX/PAC-SWI-X.html?tp=3405 http://www.crutchfield.com/p_127SWIJACK/PA...=3405&avf=N hope that helps a tad more.
00cex Posted December 16, 2008 Author Report Posted December 16, 2008 Ok thanks for the links I can find everything from there. Exactly what I was looking for New: 1998 Chevy Blazer 4.3L 2dr Alt: Unsure yet Headunit: Kenwood Excelon KDC-X494 Subs: 2) 15" Hifonics Olympus V.2's Amps: 2) Hifonics Goliath GX3000's European Version Maxx-link
