fawd06 Posted January 23, 2007 Report Posted January 23, 2007 I have a question about running 2 batteries in the back, im doing 4 runs of power and ground! im wondering if i should split the runs up per battery or should i run all them to 1 battery then run parallel to the 2 rear battery?
2000LaDe Posted January 23, 2007 Report Posted January 23, 2007 run parallel. i ran 4 powers and ground to my batteries. then off the end battery run 2 runs of ground to the frame.
fawd06 Posted January 23, 2007 Author Report Posted January 23, 2007 run parallel. i ran 4 powers and ground to my batteries. then off the end battery run 2 runs of ground to the frame. so i run all 4 to the first rear battery then when i run parallel do i run 4 runs to the second battery or is 1 run fine?
Ernesto Posted January 23, 2007 Report Posted January 23, 2007 With one you should be fine but adding extra won't hurt. Make sure you got a good alt too.
dmanson Posted January 23, 2007 Report Posted January 23, 2007 With one you should be fine but adding extra won't hurt. Make sure you got a good alt too. extra never heards. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
2000LaDe Posted January 23, 2007 Report Posted January 23, 2007 run 4 from the front battery to the rear first battery then u can run a single run from that battery to the 2nd back battery. and off that battery id runn 2 grounds to the frame. if u need a diagram i will be more than willing to design one.
fawd06 Posted January 23, 2007 Author Report Posted January 23, 2007 run 4 from the front battery to the rear first battery then u can run a single run from that battery to the 2nd back battery. and off that battery id runn 2 grounds to the frame. if u need a diagram i will be more than willing to design one. yeh that would help!!! how about wiring the amps up? i know to ground them to the rear batterries but which one? if u can get me a diagram it would help lots thanks
dmanson Posted January 24, 2007 Report Posted January 24, 2007 wire the amp(s) positive and negative to either battery. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
