Crump Posted December 19, 2008 Report Posted December 19, 2008 Does it matter if i ground it to the chassis, or should i run it to my start up battery? Team gg Team doa Installs I have doneMy 2010 Rebuild 144 db so far....2 DC xl 10s Firing into cabin on a RF 25002 12" AQ HD's powered by a Saz 2k + Lots o Mids+Highs
kentb Posted December 19, 2008 Report Posted December 19, 2008 Does it matter if i ground it to the chassis, or should i run it to my start up battery? ground to the chassis should be good. but people will argue that straight to the batter would be better. if you have extra wire, go for it. but IMO, just ground it on the chassis. New System 2 10" Fi SSD, Sundown 1500d Build I build and design enclosures(cheap price), PM ME Kicker L7 Navigator(plexiglass, fiberglass, aeroport) Build BTL 18" Escalade(plexiglass, battery tray) Build http://www.kentbaudio.com Old System
Crump Posted December 19, 2008 Author Report Posted December 19, 2008 ground to the chassis should be good. but people will argue that straight to the batter would be better.if you have extra wire, go for it. but IMO, just ground it on the chassis. ok thanks Team gg Team doa Installs I have doneMy 2010 Rebuild 144 db so far....2 DC xl 10s Firing into cabin on a RF 25002 12" AQ HD's powered by a Saz 2k + Lots o Mids+Highs
sayhuh? Posted December 20, 2008 Report Posted December 20, 2008 ok thanks Both. You should run a neg from the front to the rear battery (like you would your power) and also ground the rear battery to the chassis. But as stated you can do just the rear to the chassis and hope you have a good ground up front. (i'd do both if you can) Blown
