Zfrerichs's 01 Dakota floor project started
baffles dry fitted with 3/4 mat
Posted Image
Posted Image
wetted out
Posted Image
Posted Image
down the port no glass just resin to seal up the mdf
Posted Image
Posted Image
the small piece that goes across the front. screwed and glued. i was going to use nails but the werent long enough to go threw the double piece and hold on the side
Posted Image
Posted Image
Posted Image
Posted Image
Roseville, CA
front edge sealed up with tape to hold shape and stop leaks on the bottom edge
Posted Image
Posted Image
Posted Image
Posted Image
pieces pre cut
Posted Image
what i do is cut my pieces to fit without creases it makes a seam but then i just put a small piece over the seam just as strong with no air bubbles this piece is for the corner
Posted Image
three layers of mat
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Roseville, CA
Looking fucking spectacular bro :clapping:
keep the pic coming and keep up the good work. :good:
CURRENTLY UNDER RE-CONSTRUCTION
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
Team SMD (Street Motivated Devastation)
thanks yup will do lol. is been hard to get my ass out there its been fucking freezing but today wasnt too bad hopefully tomorrow will be the same
Roseville, CA
i got the baffle and port glassed up
Posted Image
Posted Image
Posted Image
Posted Image
i put another three layers on the front egde
Posted Image
Posted Image
Posted Image
Posted Image
third baffle test fitted im going to have to make another one the router i was using wasnt made for the jig and i didnt know its only alittle off but it makes a huge diffence
Posted Image
a little far
Posted Image
way to tight
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Roseville, CA
seeing as how your usta glassing shit how bout you do my door pods :P
and hurry up and get this shit back in the dakota
R.I.P!
(Nov-29-2009)
92 explorer
current build
mock up with port attached making the pieces for the center divide will be a bitch but it has to be done!
Posted Image
Posted Image
Posted Image
the top edge i think im goignt to attach the baffle and then hit the top with a belt sander to flush it all up
Posted Image
i sanded the baffle to port smooth it was of by like a quarter inch in some spots but its all flush now
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
its alot better than it was
Posted Image
Posted Image
if you open this pic and look at the top edge you can see how far off it was in some parts
Posted Image
Roseville, CA
haha im in no rush i almost forced myself to do a couple other things today and i was like naw im in no rush im going to take my time for sure.
Roseville, CA
i'm just fucking with ya box looks amazing alot better then what i could do...
your running 2 12 btls and a rockford t40001db
R.I.P!
(Nov-29-2009)
92 explorer
current build
