F N LO Posted January 24, 2007 Report Share Posted January 24, 2007 Alright im not sure if this thread should be in this section , but i thought it was appropiate, if i am wrong someone movee me please, Ok i want to ask the question, how do i find the size of port/size of box tuning frq... i recently tried using "the12volt.com" , and i punched into their calc that i wanted a 35hz freq., and after i got the box done completly to spec, my box is hella loud at ike 45 hz... 10hz is pretty far off no?? So if someone could please help me, i would like to know theories, explanations w.e., i have be going crazy reading up on ROE, they have alot of tutorial/info but i thought id come to you guys for my questions... Thanx for your help! Quote Link to comment Share on other sites More sharing options...
andym85 Posted January 24, 2007 Report Share Posted January 24, 2007 here are a couple of tuning calculators... http://www.linearteam.dk/default.aspx?page...=ventcalculator http://www.carstereo.com/help/Articles.cfm?id=31 general rule of thumb is like 12"-15" of port area per cubic foot of box. longer port=lower tuning. shorter port=higher tuning. if you increase your port area your tuning freq. gets higher, if u decrease your port area, your tuning freq. gets lower. couldnt tell if you can find the cubic footage for your box or not, im sure u probably can, but just do l*w*d (internally and in inches) and divide by 1728 to get your cubic feet. dont forget that sub and port displacement is also gonna take up volume in your box... Quote i likes me some audio stuff... Link to comment Share on other sites More sharing options...
F N LO Posted January 24, 2007 Author Report Share Posted January 24, 2007 i built the box to 1.5 cubes, per sub, both in seperate enclosures, same box... my port is 3 in dia. and about 10.5 inches long.... Quote Link to comment Share on other sites More sharing options...
F N LO Posted January 24, 2007 Author Report Share Posted January 24, 2007 and according to the linaer site, it says i should be hitting 32hz, however when i try my subs at 32 hz the cant keep up, they skip, and what not... maybe i should look into my gain settings?? Quote Link to comment Share on other sites More sharing options...
andym85 Posted January 24, 2007 Report Share Posted January 24, 2007 if you mean your subs cant pick up the low notes, then yea, try adjusting your gains. and just because you tune it at 32 doesnt mean its going to peak at 32 on the meter... Quote i likes me some audio stuff... Link to comment Share on other sites More sharing options...
F N LO Posted January 25, 2007 Author Report Share Posted January 25, 2007 so if i tune my box to 32hz, how does that relate to the sound i hear?? also how do i find what a good gain setting is, i have a pioneer deh 6800 mp.... i adjust my gain according to output from the preamps right?? where do i get this info?? Quote Link to comment Share on other sites More sharing options...
F N LO Posted January 25, 2007 Author Report Share Posted January 25, 2007 what kind of advntage is there to haveing external ports?? Quote Link to comment Share on other sites More sharing options...
Dale Posted January 25, 2007 Report Share Posted January 25, 2007 what kind of advntage is there to haveing external ports?? You can adjust the tuning frequency without using internal box space. People sometimes do that if they're tight on space. Another way to get the most out of internal space is to mount the subs upside down...that is firing into the box. Quote Link to comment Share on other sites More sharing options...
andym85 Posted January 25, 2007 Report Share Posted January 25, 2007 i was just saying that tuning it at 32 doesnt mean you will peak at 32 on the meter. but a low tuning like that should allow you to pick up most low notes. i think im tuned to like 32 or 34 and i pick up some hella lows. as far as setting the gains, check out the sticky in the sub section about it... Quote i likes me some audio stuff... Link to comment Share on other sites More sharing options...
F N LO Posted January 27, 2007 Author Report Share Posted January 27, 2007 does anyone know the actual thereoy to calc. this?? i would just like to know for shits sake.... thanks for the links and explanations guys... Quote Link to comment Share on other sites More sharing options...
