I HAVE 4 15" DUAL COILS 2OHM L7 KICKER SUBS AND 2 HIFONICS BRUTUS 2200WATT AMPS MODEL BX22OOD AND THIS AMP IS STABLE TO PLAY AT A 1 OHM LOAD. I HAVE ALL THIS IN A 99 TAHOE, I ALSO HAVE A 15 FARAD CAP "THE CAP" AND A DUAL OPTIMA BATTERY THIS SET UP HIT HARD BUT I FEEL LIKE IT CAN DO WAY BETTER ANY ADVICE ON HOW TO HOOK UP THE SPEAKERS OR WHAT I CAN CHANGE TO IMPROVE THE PERFORMANCE ON THIS
lose the cap and upgrade to a better alternator.how do you have all four subs wired at?
That's why they don't deliver.
Yer ass better go sit along the side of the road and wait.
You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start :D
I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do.
what kind of box do you have it in?sealed?ported?did you buy the box or did you build it?
well im probably taking it u have 2 subs wired to 1ohm per amp if not thats how it should be and id also say ya need to upgrade the alt and if the box is sealed id go ported for sure. :good:
WHATS THIS.........POKE HARD????
nope more then likely he'd have the subs at 2 ohm for two subs
oops my bad read it wrong thinkin it said dual 4 ohm :pardon: yeah your right.
it's all good man.and maybe change up the batteries too to more power ful ones maybe kinetik or powermaster.
THE ALTERNATOR IN THE TRUCK IS A 140AMP ALT. AND THE SUBS ARE WIRED ALL POSITIVES AND ALL NEGATIVE THEN INTO THE AMP WHEN IT GOES IN TO THE AMP IT IS IN BRIDGE MODE SO I DONT KNOW IF THE WIRING IS HOOKED UP WRONG ALSO THE BOX IS MADE TO FIT THE BACK OF THE TAHOE AND IT IS PORTED....ANY SUGESTIONS HOW BIG SHOULD THIS BOX BE AND HOW BIG SHOULD THE PORTS BE AS WELL
THEY ARE WIRED IN PAIRS I HAVE 2 SUBS TO EACH AMP AND THEY ARE WIRED POSITIVE TO POSITIVE ONE SUB TO POSITIVE TO POSITIVE TO THE SECOND SUB THEN INTO THE AMP
some pics would prolly help out a lot, especially of the port, and box construction
Orion 2500D, Jbl Gto 75.4
Team Wolfpack Audio FSQ 15" d2, mb quart xover, tweets peerless 6.5 mids
Alpine cda-105
optima up front Knu klm 1/0
  • Who's Online   0 Members, 0 Anonymous, 4082 Guests (See full list)
