el chiludo Posted December 23, 2008 Author Report Posted December 23, 2008 some pics would prolly help out a lot, especially of the port, and box construction [/quote I DONT HAVE ANY PICTURES OF THE BOX OR THE PORTS AS SOON AS IT STOPS RAINING I WILL PULL THE TRUCK OUT AND SHOOT SOME PICS Quote
Torres Posted December 23, 2008 Report Posted December 23, 2008 caps man caps...lose the caps. it's like you're yelling. and if you have all positives of each pair and all negatives of each pair connected per amp...then you're wired at .5 ohms. that's too low of an ohm load for those amps imo. i'd suggest getting a more appropriate amp and wiring those amps to 2 ohms until then Quote
el chiludo Posted December 25, 2008 Author Report Posted December 25, 2008 caps man caps...lose the caps. it's like you're yelling.and if you have all positives of each pair and all negatives of each pair connected per amp...then you're wired at .5 ohms. that's too low of an ohm load for those amps imo. i'd suggest getting a more appropriate amp and wiring those amps to 2 ohms until then WHAT DO YOU RECOMEND TO RUN ON THIS INSTEAD OF THE HIFONICS AND WHATS THE PROPER WAY TO WIRE UP THE SUB. Quote
