so I pulled the cover off and there is a nickle-sized smoke/black mark on the board by a resistor. So back to what is a good cheap amp, 800-1400 watts, 4,2,or 1 Ohm, and under $150?
K well i opened up the amp and found a burn and what looks to be a screw that gorund the board to the case. If the case isn't grounded would that throw it into protect?
Burn
The Ground Screw???
The screws really aint to important. It dont matter if the amp is grounded to the heatsink or not, since there is a external ground being connected directly to the amp.
The screws hold the board tight from sliding and moving in the heatsink.
Looks like some burned mosfets.
Well I got a new amp. I got a Sony Xplod ZR1252B 800watt max. I know its an Xplod, but for $20 I have a 4 year protection plan. Best Buy will replace or fix it if it fries, shorts out, etc. It seems like a decent amp for 1 or 2 10"s. How do sony amps hold up? I know their head units suck.
  • Who's Online   0 Members, 0 Anonymous, 656 Guests (See full list)
