Slapmaster's Official Monster Groundpounder Build Log. 60+ Speakers And Counting
alt gave me hell getting in. it fits fine but had so many harneses and hoses that did not want to budge...lol
got two of the big three don. tomorrow i'll do the third, 1/0 batt to chasy. i got 2 8' runs of 1/0 that i'll run from the front batt to the inside sence i got the engine cover removed from the inside and don't want to got threw the truble of buttenning it up and takeing it back apart in the future. lol i'll just use cupplers to complete the two runs all the way to the back.
Posted Image
One thing that might be something to watch for- your engine to chassis ground has very little slack in it- the motor is going to move and vibrate and that ground may need a bit more slack. Just keep an eye on it.
Great job and keep the pics coming!
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
yah, i thought about that when i chose that location. while i had the engine cover off, i put the van in gear and gave it some gas while i held the brakes. that ground wire only moves about 1/4". i'll keep an eye on it cause i know over time it will ware on the ring connectors. it was a premade piece that i used on my bank of batts in my car.
Great build bro, i see ya know, that understand how much we love pictures :D
the build is coming real nice, that fur is PIMP...
IM TUNED IN... :dj:
CURRENTLY UNDER RE-CONSTRUCTION
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
Team SMD (Street Motivated Devastation)
anything new happen with this?
R.I.P!
(Nov-29-2009)
92 explorer
current build
got tha alt install and the regulator installed and working. this weekend i'm going to start on the front doors. i'm thinking about slicking them out and painting them with the same textured paint as i did with the rear pods. i'm thinking all the glassed pieces i do should have same look.
what do yall think?
should i do the front doors in gray viynle(spelling), or should i paint them with the same textured paint as i did with the rear pods?
cought hell after i got the regulator wired up. the lights started flickering. did a little reserch on the matter on here. found out that i shouldn't wire the relay off the fuse box but , needed to wire it straight off the batt....works 100% now
Posted Image
