u can get a dmm at walmart for 20 buck i got mine there its the shit dose everything more expensive ones do of couse the have cheaper ones to i think the cheapest is 10 bucks buts its analog not digital
2 15 RE SE
1 Audiopipe 1500d
Sony HU
Batcap 800 in the back
Team Tex~Flex
when you switch the rca's around, does the other channel work? If its happening on both amps you tried, then its more than likely the rca's
816-591-6592
www.kcrimshop.com
Ill mess with it more tomorrow morning, its freezing,late, and im tired.
The vid is 60% done downloading
2002 FORD EXPLORER PACKED WITH SOME CHEAP SUBWOOFERS!
Finally a video, back comps are unwired and door comps are turned down because they have about had it, so not much treb.
Posted Image
decent video... are all the subs the same ohms? since u got them at different times maybe one pair is 2ohms and one is 4ohms.... im just geussing here cause i have no idea why it wouldnt work
1996 deville on 18" full face rims
-2 gauge wire.
-a2400db
-RE SE-X in a 4ftc box tuned to 32hz
-tview touch double din
-rockford punch 6x9s(rear)
-mtx 6.5(front)
front and rear stage will soon be changed build log will start as soon as it aint cold!
sounds pretty smooth :)
1990 Jeep Cherokee 4X4
Pioneer DEH-P2900MP, Big 3 done in 1/0, 1 run 1/0 ran to amp
DAT HF1000.1 #007 powering a DC lvl4 15
DAT HR 4085 prototype powering 2 Selenium 6s and 2 no name tweeters running active
1st place in AS3 @ Surf City Sound Off, 140.8 @ 45hz @ the headrest.
rebuild coming soon to get a better score :)
"I regard the brain as a computer which will stop working when its components fail. There is no heaven of afterlife for broken down computers; that is a fairy story for people who are afraid of the dark."
