Menace89 Posted January 6, 2009 Report Posted January 6, 2009 Can someone check my math for me please...i wanna make sure before i start my new build Box is 5.77 cu ft after displacement tuned to 36Hz Port is 2.75" x 26.5" and 17.84" long thx
Nightshade Posted January 7, 2009 Report Posted January 7, 2009 That's a big 10 4 on the calculation. I got the same exact thing. You may get some port noise from that port since it's not very wide at all. The air will probably struggle to get out of the box creating a whining or whistling noise at the port exit. Try making it a bit wider and taking some away from the length. 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
Menace89 Posted January 7, 2009 Author Report Posted January 7, 2009 cool thanks....i just wasnt 100% cuz with the calculator i used if i put 26.5 as the height and 2.75 as length i got 17.84" but if i switched em it said like 7.89" i think how bout 3.5" x 20.8125" and 17.46" long sound better?
Nightshade Posted January 7, 2009 Report Posted January 7, 2009 cool thanks....i just wasnt 100% cuz with the calculator i used if i put 26.5 as the height and 2.75 as length i got 17.84" but if i switched em it said like 7.89" i thinkhow bout 3.5" x 20.8125" and 17.46" long sound better? That should work out a bit better. Good luck getting the .8125" on the height It's possible to find that exactly, but I wouldn't worry about being that precise. Your only talking about a hundredth of a hert difference if it isn't perfect. 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
