Dunno what kind of amp i should get?.............Help
alpine
give em 750 rms each and they will sing real nice. (if they are in a properly designed/built enclosure, and they will play all day long)
Id reccomend a Brutus 1606d or 2006d
2x on that.... Isn't that what I told you online
SMDsigbannr4.jpg1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
U can get a Rockford T15002BD for around $600 and run 2 subs per channel because its a 2 channel amp....That amp is rated 750x2@1ohm but the test sheets say more like [email protected] u would get about 500-600 rms to each sub. Or yea like they said before the Kicker would be good too. But if u want something real nice then I think u may wanna up ur budget on that amp a lil more.
00114-1.jpgTEAM MechMan Alternators
yea but isnt that birth sheet at 14.4 Volts tested...
yeah it is at 14.4 ......... regardless you'll still get more than power than any other amp. RF is just underrated all around. 1100X2@1ohm, if the voltage drops. you'll still get near 1000rmsX2@1ohm.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   0 Members, 0 Anonymous, 1249 Guests (See full list)
