Beckett Posted January 8, 2009 Report Posted January 8, 2009 i've normally been havin my alpine run like this; 1100RMS at 2 ohms at the amp, -7 on my alpine head unit. was pretty loud , the sub was moving enough. not sure how much power the R would have been seeing like that? 14.4 volts constant it see's when wanging full tilt. now i have turnt the head unit up to -2 bass on the head unit, and have the bass knob, just over half way. it's louder than before, subs moving more than it did i'm loving it lol i'm really curious as too how much power it's actually seeing? i figure it's seeing like 550-600 probly? cus the amps set at 1100 at the gains, and head unit is -2, bass knob half way, so i'd guess that would be about right? LOL i could turn the bass nob up more for certain songs but some are a bit too much excursion and i don't want to blow the R. when i turn it jus over half way with HOLD THAT THORT and smell in the port, there is a slight burning smell. jus gets a tiny bit smelly lol that should be fine ? cheers Ben x JS Fraser *Alpine Typr-R 12" *JBL GTO 1200.1 Sub Amp *Alpine PDX-4.100 *Rockford Fosgate Power 6.5's *Rockford Fosgate Fanatics 6.5's Both in front doors *0/1 Guage wiring from front Junction Boxes to 120AH Battery In Boot (battery removed because too small for alternator) *140 Amp HO Alternator *Alpine Head Unit -------------------------------------------------------------------------x------------------------------------------------------------------------------
AI James Posted January 9, 2009 Report Posted January 9, 2009 theres no way to tell on music what its getting, if you set the gain with a tone and oscilloscope then that will give you a good estimate where you are though
Boon Posted January 9, 2009 Report Posted January 9, 2009 When you set the gain what did you have the headunit set to? 10.x volts fo' life!
Beckett Posted January 9, 2009 Author Report Posted January 9, 2009 volume 26. everything on zero bass trebele sub etc JS Fraser *Alpine Typr-R 12" *JBL GTO 1200.1 Sub Amp *Alpine PDX-4.100 *Rockford Fosgate Power 6.5's *Rockford Fosgate Fanatics 6.5's Both in front doors *0/1 Guage wiring from front Junction Boxes to 120AH Battery In Boot (battery removed because too small for alternator) *140 Amp HO Alternator *Alpine Head Unit -------------------------------------------------------------------------x------------------------------------------------------------------------------
