Thanks for all the advice guys, but how would i go about setting the lpf on my sub amp for the best output at 32hz per say or 35hz? i say the advice "banging caddy" gave fi-beat-down, but it doesnt seem to be working for me.
This is the diagram i used:
Here is the original post its from:
http://www.stevemeadedesigns.com/board/ind...showtopic=33800
CURRENTLY UNDER RE-CONSTRUCTION
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
Team SMD (Street Motivated Devastation)
If your LPF is above 35hz then changing it won't make a single difference to how your system plays 35hz. If for some stupid reason it's below 35hz then it will mess with any notes above whatever it's set to.
Set it to 80-100hz.
Chances are if you can't play 32hz well then you have a problem with your box.
10.x volts fo' life!
the lpf is going to set the high end of you freq range for the low end you mess with the subsonic filter
