yea james i think u messed up colder air is more dense than hot
*edit* comp is slow
lets assume a 40 hz frequency ok?
constant
the box type size shape and tuning are the variables. how do i determine how to create the best box for that one frequency?
Edited by IH8PunkRok
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
cold air is way more dense so waves travel alot easier. the longer the wave the louder it can be because the shorter it has to travel just need to crank it..(in other words it has the capability of getting louder than a shorter wave does but it requires more energy to get to its peak compared to a 60hz
The set up your talking about would sound great in my Tahoe. Trade you my dog for it. He has one eye but that only makes for bad depth perception so hey so what if he is running into shit, look at it this way he is easy to sneak up ninja style on. (right side only)
</div>
im gonna call false on this one. all frequencies can obtain the same decibel reading. im pretty sure there is no capp to any certain frequency. in any case that doesnt help me with the tuning aspect of the enclosures. good try tho
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
*edit* comp is slow
constant
Box volume and box tuning.... Also knowing, for a lack of better words, how much freq. rise your vehicle likes. Ex. My box is tuned to 33 hz but i peak at 40Hz. 7 Hz rise, increase.... I can't think of the right words. but every vehicle peaks 5 to 10 hz higher then box tuning.
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
ok and that peak rise has to do with the increase of volume from the box to the cabin correct?
*edit* shouldnt the new peak be a lower frequency if the air volume is larger?
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
I believe in most cases the freq. of the vehicle depends on how much airspace is in the vehicle. Thats why most standard cab trucks are around 50 hz or so and a vehicle like my friends Excursion like the mid to upper 30's.
I do box designs.
so that itself is a totally different beast isnt it?
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
I am having a brain fart, i don't understand what you mean?^^^^^
I do box designs.
cabin tuning
its a completely different aspect of the acoustics
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
sorry I left for a bit.
Here are a few tidbits.
Colder air can be more dense but is not always more dense than hot air, humidity and altitude also come into play here.
Also, it isnt necessarily easier to get louder in more dense air.
30 deg F air to 80 deg F air will show very minimal differences in density, so any difference in SPL based soley on density is very minute. Also, the more dense the air is, the harder it will be to achieve the same SPL as with a lower density. This is because the air shows more resistance. Basically you have more air molecules to push so more energy is required.
Now, we know that sound travels faster through dense materials like solids than it does through lesser dense materials like air.
So basically the denser the air, the faster the wave can travel Changing the resonant frequency of the car and the enclosure.
Based on that theory we can say that SPL will be lower in more dense colder air, but the change in density is too small. Also, with a higher frequency you can create more energy per time. So lets says 60hz is 60 full waves a second compared to 30hz 30 full waves a second.
So it really effects frequency, and some systems are setup to play better at some frequencies than others, so if the temp drop changes your cars frequency, and you box doesnt matches it better than the hot air, then you score may go up. This can be predicted but it is extremely difficult.
Now lets talk about box tuning.
You can figure what size a box has to be for a given frequency based on the data of the sub. Cone mass, Motor strength, Moving force. Things like that can tell you how the woofer will move and react to a given power and air volume.
Now the car. Just think of the car and box together as a big bandpass. So you have 2 chambers. The Larger chamber is more related to the length of the wave, so larger vehicles usually play lower, smaller vehicles usually play higher.
If you tune a box to say 35hz, those formulas used to calculate that are based on infinite airspace around the box, and dont take into account a vehicle's internal volume. So when you shrink the infinite airspace down, you raise the tuning frequency of that enclosure.
It is true that in most cases it will raise 5-10hz above what the box is tuned at but is hard to calculate exactly because of the various shapes and sizes of different cars.
Sorry if I wasnt too clear, I have been drinking.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
  • Who's Online   0 Members, 0 Anonymous, 3059 Guests (See full list)
