Jl Audio W7
uhoh_45
i've never actually played with a w7 before and was wondering how do you mount them, the screws are under the surround.. if some one can chime in here with some pictures or something it would be greatly appreciated
R.I.P!
(Nov-29-2009)
92 explorer
current build
go to www.jlaudio.com ....... you can see the pics on how to mount them there.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
One of the first things you notice about a W7 is that something is "missing"... the mounting flange. Of course, this is actually not the case. The mounting flange is simply hidden beneath the surround and is made accessible (for mounting purposes) by detaching the outer edge of the surround and moving the roll to the inside (a pretty neat little trick). Apart from the obvious benefits of amazing your friends as you pull the surround off your speaker, there is a serious technical issue that led us in this design direction: Effective Piston Area (“Sd”). This is essentially the speaker’s “cylinder bore”, to use an automotive engine analogy, and is calculated by measuring the diameter of the diaphragm including one-half of the surround roll-width. In other words, from the top-center of the surround on one side to top-center of the surround on the other side.
1997 4 Runner
Alpine CDA-9886
4 Fi Audio X Series 12's
1 Crunch GP3000D Pro
DC Power Inc. Alternator(Kickin out 15+ volts!)
  • Who's Online   1 Member, 0 Anonymous, 1269 Guests (See full list)
