Just Started on my First box tonight and so far so good here are the pics, and the pics with the top of it on and port done isn't true I just put it together just to see how it would look!
FeedBack?
4 15'' Big Perm Subs in a Custom Built Box.
4 Kenwood Excelerion Mids.
1 RockFordFosgate T4000.Bd
1 Alpine 500w.
Alternator: Dual Alternators 1 stock- 1 300amp 180 at idle alternator.
Batterys: 4- 1 for my engine, 3 yellow tops
Check Out My YouTube
Add Me on MySpace
After a Hard Days Work with a Buddy I think a High 5 is needed!
MY Building Equipment: SkillSaw, JigSaw, Drill, Screws, Glue, 2 People. and a VERRY FUCKEN BIGGG THANK YOU TO
UHOH_45 FOR THE DESIGN!!!!!
Edited by AkPride
1 Alpine 500w.
Add Me on MySpace
it will be double baffel I just thru that one for a test look to see how it would look in the end the subs will be flush, I'm gonna have them into that first baffel and then throw another one on top to make it flush for a better look.
bracing- One will be over the port connecting to the front part of the box and the other one will be over it right under the baffel going to the left and right walls.
I'm out for the night got work in the morning so more pics tomorrow night.
Edited by AkPride
1 Alpine 500w.
Add Me on MySpace
wheres the bracing man
R.I.P!
(Nov-29-2009)
92 explorer
current build
