you built the box to fit so tight into the front of the trunk it may stop some of the pressure waves from reaching the front of the car. this causes really loud to equal losso rattle.
-Drew
way to steal my thunder... :8)
CURRENTLY UNDER RE-CONSTRUCTION
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
Team SMD (Street Motivated Devastation)
Great minds think alike :8)
this is a sport of preference and last i had a box that tight i liked the sound :)
-Drew
uhoh_45 said:
-Drew
haha, ill take the compliment :D
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
well i went out and boxed the box out a little away from the back of the seats and i didnt really notice an differnce in the bass for whatever reason. but im wondering now.. because i am putting bigger ports in. that since the box is like to smaller boxes together are the ports gonna be screwed up if there is a wall right behind them instead of being open inside the whole box. dont know if that made sense
http://i230.photobucket.com/albums/ee307/b...12/SDC10113.jpg
that pix shows the ledge between the two boxes, does it matter that the ports are directly facing that?
your suppose to leave how ever many inches your port or ports in diameter are away from any obstruction, say you are using a 6" port, try to leave 6" from the end of the port unobstructed if you can, unless it will mess up your tunning but the more the better
Edited by TCA1689
ive been thinking... hopefully someone can help me out. would it be better to just add a slot port to this box instead of my two 4" ports. i think i can make it about 4" high and how ever long and wide i need.
6*12=72sqin.... minimum for slot port
u have
2*12.56=25.13sqin...
u need 2 more 4" ports to have enough port surface area when using aero ports
add another piece of mdf the same size as the front (where the subs mount)... u likely have flex since there is no bracing... so that will help with distributing the weight (~70lbs) and make the box stronger
personally, id make another box
slot port... with bracing... and if you have to make a section smaller, try to eliminate all 90 degree angles
like this... pardon how crude... took seconds.. maybe not that big of 45s but u get the idea... much more efficient
Edited by decafcappucino
