Sub Help!
im running 2 mtx thunder 5500 subs in a ported mtx thunder tc box
600w rms 1800w max, exile 500.1 amp 500w rms 1000w max, headunit is panasonic
CQ-VX100 7" receiver, stinger 8 gauge for everything.
Problem is the one sub sounds different/ almost disstored? then the other and sometimes
looks like its moving at the opposite time as the other i have checked wiring
and all looks good cannot find the problem?
98 Dodge Durango
12 000K 50/55W Headlights
12 000K 35W Fog lights
HU Panasonic CQ-VX100 7" Reciever
(1) Fi SSD 18" Fully Loaded
(1) Ported box 33hz
(1) Soundstream TRX1500D
(1) Soundstream TRX2.440
(1) RE 6.5" Component Set
(1) Rear battery
Big 3 in 0/1 gauge
2 runs of 1/0 Gauge wire
250A Alt soon..
Didn't we address this before?
http://www.stevemeadedesigns.com/board/ind...c=36069&hl=
Edited by bigbodylexus
1990 Chevy Suburban (Big Booty Judy)
(4) Sundown Audio Zv5 18's
(1) Sundown Audio Salt 12K
(1) Sundown Audio SAX-100.4
(1) Sundown Audio SAE-50.4
(2) Crossfire ST-1 Tweeters
(2) Obsidian Audio ST-1 tweeters
(4) Sundown Audio Neo Pro v3 6.5's
Saving 2nd Bass
yes, ok take a DMM to see what ohms your subs are sitting at, find out what impedance you want your amp at and wire accordingly, also make sure not to cross over any wires which could possibly be the problem right now.
Team_DC-Derrick's Youtube
Team DC Audio
the subs are wired at 2 ohms together. there wired to one post terminal on the box
dont know if that could be the problem go the subs wired in the box when i bought it.
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
do you have it wired to your amp at 2 ohms or 1 ohm? me personally i would take my subs out check them to be on th safe side *you never know could have a d4 and a d2 in the box... check them then re wire them and try to make the wire the same length and wire up to the amp
the speakers that i looked up the 5500 says its d4 which you can either wire them up to 1 ohm or 4 ohm
http://www.the12volt.com/12voltimages/2_4ohm_dvc_1ohm.gif
http://www.the12volt.com/12voltimages/2_4ohm_dvc_4ohm.gif
Edited by Army_guy614
Team DC Audio
well according to mtx the impendence is 2 ohm. i know when i first got the subs they were fine its just been
the last couple weeks the one is sounding and acting diff from the other?
http://www.mtx.com/caraudio/products/enclosures/TCE5500.cfm
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
http://www.mtx.com/caraudio/products/subwo...thunder5500.cfm
says otherwise.. unless you are running diffrent subs you got d4
*edit
you was looking at enclosures btw not the subwoofers
Team DC Audio
yes i know that enclosure comes with the subs though
the impendance is not the prob im having the amp is
fine running them. its just the right sub in the box
sounds way more distoreted the the left /
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
which is probably the way you have it wired up.. you can either go 4 ohms or 1 ohm with your subs, and you should try to wire it up as so...
Team DC Audio
question then it came pre-wired from mtx to start and why was the sub not doing this
when i first go the subs its just been a recent thing?
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
  • Who's Online   1 Member, 0 Anonymous, 1254 Guests (See full list)
