f150JLkid Posted January 30, 2007 Report Posted January 30, 2007 k guys heres what I Got. I got 2 JL 500/1, 4 JL 12w3v3. So I need a box that fits in with in these dimensons. 22" x 56" x 25". would it be better for each sub to be in each individual box or 2 in a box. it needs to be ported. its going in a 2000 ford f150 extended cab. back seats out I listen to rap so, it should be tuned pretty low am I right. around 28-40?? SPL, is what im going for. thanks guys, any replies would be appericated. Josh
sean 371 Posted January 30, 2007 Report Posted January 30, 2007 Tune between 30 and 33hz. I personally like individual chambers for each sub, but its up to you. Here's a link to the specs that JL recommends for your subs. Those tend to work real well for overall daily use. http://mobile.jlaudio.com/products_subs_en...hp?series_id=25 A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
dmanson Posted January 30, 2007 Report Posted January 30, 2007 or you can do one big box and run a chamber in the middle so two subs will play in one chamber off one of the jl500/1s and the other two subs will play in the other chamber off of the other jl500/1 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
f150JLkid Posted January 31, 2007 Author Report Posted January 31, 2007 yah im sort of looking at the second idea. looks like it will be sweet. just needed to kno some dimensions for that for my subs. thanks for the replies
ChevyBoy Posted January 31, 2007 Report Posted January 31, 2007 always run one chamber per amp, unless the amps are connected together.
dmanson Posted January 31, 2007 Report Posted January 31, 2007 always run one chamber per amp, unless the amps are connected together. that's exactly why i can't up with two chambers, two subs in each chamber unless you can take those two JL500/1s back and get a JL1000/1 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
