ok
1. battery + to alt.
2. battery - to chassis/body/frame.
3. engine block to chassis/body/frame.
if you want' date=' to be protected more, [glow=red,2,300']put a fuse between your battery and alt wire.[/glow]
Yea I heard, This can cause fires if u dont.
What is the best place to ground a wire from the engine block,
And Does it matter where u bolt your wires on the alternator
ok
Ive never look at mine. I will check it out and thanks for the tip anyway.
Windows Xp1 40 & 120gigHDDMSI BoardUNDERCONSTRUCTION Dr. Doom aka StarScream3kDestruction at ur service
i actually had the same question as bassmachine. i just wanted to know what size fuse should i put between my battery+ to my alt+??  im using 1/0 awg and my fuse going from my battery to my batcap is 250amp. should i use a 250amp fuse from my batt+ to my alt+?? this is the first time im doin the big 3 and i dont want my car going up in flames
ok
And Does it matter where u bolt your wires on the alternatorwhatve you been looking at? look for a stud on the back of the alternator that should already have a wire going from that to the battery sometimes. attach it to that. the engine block, anywhere theres a bolt and isnt in the way of melting the wire or getting stuck in a fan or something. be smart.
what size is your alternator? thats what size fuse you should use.
starts easier/quicker, and should charge a little faster after a big bass drop. and yes, a little higher/[glow=red,2,300]more constant voltage[/glow].
4show
  • Who's Online   0 Members, 0 Anonymous, 4348 Guests (See full list)
