Enclosure For Two Fi Q Series Fiteens
jizazz12
can someone take a look at my measurements and tell me if I'm on the right track with this box. as said before this box is for two q 15's 16x38x28 outer dimensions 8.12 cuft. before displacement.
after displacement 7.49 using two psp 4'' flare ports, ports will be 9.61" long tunned to 28 hertz. if this doesn't sound right sombody let me know open for suggestions .
2007 Chevy Impala LS
1 Crescendo 3KWP
1Crescendo C1000/4
2 DC lvl 4 15's with lvl5 dual .7 coils
1Audio Control Matrix
1 Pioneer P880PRS
1 300 amp Iraggi alt
All power runs done with Knu flex 0/1 guage
1 optima yellow top under the hood
1 XS 5100 and two Deka's in the trunk
4 Crescendo MP-8 mid bass drivers
2 DB Drive p5 5 D Pro Audio tweeters
38w*28d*16h
i got:
7.49cuft
26.84hz
3.3sqin/cuft...... but that is not enough port surface area
uve gotta do at least 4 4" ports at 17" long
personally id just do a slot port box with those dimensions
if you can make the box bigger it would help
38w*28d*16h
i got:
7.49cuft
26.84hz
is that going to be 17" befor the flare or is that 17" including the flare? I do't have the room for a slot port this going to be a real tight squeeze . I appreciate the help this will be my first box , that i built anyway thanks for the help.
1 Crescendo 3KWP
1Crescendo C1000/4
1 Pioneer P880PRS
4 4" ports using the entire length of the port, which is 18," but since its a flare, only have the opening is accounted for the port length.... which means that with no modifications, u can use the whole aeroport
again tho... thats a minimum
thank's for the help.
1 Crescendo 3KWP
1Crescendo C1000/4
1 Pioneer P880PRS
  • Who's Online   0 Members, 0 Anonymous, 4519 Guests (See full list)
