Bam Bam Posted January 19, 2009 Report Posted January 19, 2009 I was wondering if anyone has any test results for this amp at 14 and at 17 volts. I have heard great things about it but never any numbers to support it. It is a beautiful amp and does 5200 watts at 1 ohm. This amp is entirely to big to produce only 5200 watts. it is even .5 ohm stable. Any info would be greatly appropriated! Bam Quote 6 Funky Pup 12's
Boon Posted January 19, 2009 Report Posted January 19, 2009 Does more like 3700w @ 1 ohm @ 14v. The output section is too small for much more. Quote 10.x volts fo' life!
Bam Bam Posted June 12, 2011 Author Report Posted June 12, 2011 This amp will definately exceed 5000 watts at .5 ohm. It is current hungry so it must be fed plenty of amps and the voltage must range between 13.8-17.5 to reach 7000+ watts! Quote 6 Funky Pup 12's
TeamHT Posted June 13, 2011 Report Posted June 13, 2011 :facepalm: Quote Tell me...does this smell like chloroform to you?
CaptainzPlanetz Posted June 14, 2011 Report Posted June 14, 2011 :facepalm: ^^^^^^^That Not only is the thread old, but also he isn't taking Boon's word for it. Quote ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
Bam Bam Posted June 16, 2011 Author Report Posted June 16, 2011 Lol! I don't need to. I have had it tested. Quote 6 Funky Pup 12's
