Bandpass Design Help!
sean 371
K, so here's my first bandpass design that I've done by hand (w/o winisd or another program).  This is for an install we're doing in an F-250.  Kind of a budget system, so hopefully we can make up for it with the box.  Please just look through the numbers and tell me if this looks realistic.  Hopefully I didn't eff up the math anywhere!
Sub: Type S 12
Box Specs:
Volume of the Ported Section: 1.05 cu ft
Volume of the Sealed Section: 1.9 cu ft (is that odd that the sealed is a larger volume?)
Port Specs: 50" of port, 13.88" long.
Low cutoff: 26 hz
High cutoff: 74 hz
If I manage to get some positive replies to this, I'll go ahead and build it to see how it sounds.  Thanks guys!
A couple links to some box builds:
Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI,
Mini-Bump, Hummer H2, Ford F-150
My own car builds (current setup --- under construction):
Overall Thread, Kickpods, Dash, Back Doors
Subwoofer Wall
Post ur math.
LETs see how you got ur numbers.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
okay.  here goes.
I used .7 for my alignment (S Value), b=.7206
I picked 26 hz for my lower cutoff.  (Fl)
Fl' = (Fl*Qts)/Fs
Fh (high cutoff) = (Fl'+B)*Fs/Qts (came out to 74 hz)
Volume of ported chamber = (2*S*Qts)^2*Vas
Volume of sealed chamber = Vas/((Qbp/Qts)^2-1)  (Qbp is the Qtc of sealed chamber)
Fb = Qbp*Fs/Qts (tuning frequency, came out to be 43.8 hz)
For Port length I took a 4" port, which I'll convert to a slot port later.
Lv = [1.463(10^7)(R^2)/(Fb^2)(Vb)] - 1.463R  (R = 2 in this case)
This came out to 13.88
I'm pretty sure the math is right, I'm not sure if these formulas are correct though.
I took these formulas from www.diysubwoofers.org/bnd/4thord1.htm
So, does this look right? As far as cutoff/tuning frequencies?
Also, it seems a lil odd that the sealed chamber is larger, anything wrong there?
Thanks
Subwoofer Wall
  • Who's Online   0 Members, 0 Anonymous, 1550 Guests (See full list)
