damn your going to need alot more batts for 6 mojos
Yeah I know. Right now I have found space for seven 2400s and ten 1400s. I'm hoping with four 300A alts that'll be sufficient.
My 300 now will take two full blown 4KWs @ 1500 RPM with only .9V drop on hard tones.
Don't worry, I'm not going to let happen what happened the first time I tried to go big. I do, however, need to pick some brains more to make sure I can do it. What do you think about that battery setup? 17 batteries.
Need an install? Hit me up.
[email protected]
shit thats alot batts
R.I.P!
(Nov-29-2009)
92 explorer
current build
what are your max dimentions again buddy?
Well building INTO the car and accounting for the curvature of the frame, 48 wide, 40 tall, and about 45 deep assuming I 45 the corners.
[email protected]
lookin good bro! when do i get to see pics of the plexi i etched for ya in there:)
Vehicle-2014 Ford Fusion on 20" cruiser alloy obsessions
Subs-4 8" sundown audio E8v3
Sub Amp-Hifonics Brutus Elite 1200.1
box-2.8cubes after all dis tuned to 32hz 4" aero
Mids and highs-2 sets of Memphis PR 6.5 components
Mids amp-Hifonics Brutus Elite 800.4
Deck-Factory Integration
Wiring-Memphis
40sqft of damplifier Pro
http://www.youtube.c...14?feature=mhee
SMD SUPER BUYER/SELLER
Don't worry. It'll be in my doors once all my speakers come in. I decided to stick with Memphis components instead of RF, so once they come in, I'll be doin the doors.
[email protected]
you dont have a design already do ya? i'd like to see how your going to squeeze 12 12s in there
R.I.P!
(Nov-29-2009)
92 explorer
current build
Well like I said, it'll be similar to 2000lade's build. Or Neil Barber's setup. Two sets of angled baffles into the box each one holding three 12s.
IF for some ungodly reason it doesn't work, I can always do 12 10s or 6 LVL 5s (similar to Charger's setup). But 48 inches wide is more than enough for three 12s side by side. And the airspace will be sufficient.
[email protected]
6 15 lvl 5s would be sweet
R.I.P!
(Nov-29-2009)
92 explorer
current build
True...but it would be hard to get all that in there properly. I really wanna do the ported clamshell though. I can't possibly go any wider because I left room for a steel frame. And technically I could just buy two more MOJOs to go that route.
Right now the vertical port doesn't perform well in this car, so horizontal is my next shot. 151 just didn't do it for me.
Got any other interesting ideas for 6 15s?
[email protected]
