fast85_gt Posted January 27, 2009 Report Share Posted January 27, 2009 ok im running three amps now and i have never done it before just one amp at a time but my queston is the remote wire on the deck is going to my exzisting amp in the back can i jump from that amp to anuther then from that amp to the last one with no issues any help please Quote Link to comment Share on other sites More sharing options...
SundownTL3.2 Posted January 27, 2009 Report Share Posted January 27, 2009 that is what i do Quote 2004 Chevy Tahoe LT........... THINKING Link to comment Share on other sites More sharing options...
fast85_gt Posted January 27, 2009 Author Report Share Posted January 27, 2009 that is what i do thats what i was thinking but i did not wont to screw anything up Quote Link to comment Share on other sites More sharing options...
uhoh_45 Posted January 27, 2009 Report Share Posted January 27, 2009 yeah it works, have my 2 sub amps running off a toggle switch and my mids/high amp off the decks remote it gives you more control if say your driving to work in the morning and dont wanna have your subs going you can just turn them off Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
EarthQuaKeAudio Posted January 27, 2009 Report Share Posted January 27, 2009 yeah, it should be ok....hey its better to be safe than sorry w/ burned amplifiers. Quote Link to comment Share on other sites More sharing options...
fast85_gt Posted January 27, 2009 Author Report Share Posted January 27, 2009 yeah it works, have my 2 sub amps running off a toggle switch and my mids/high amp off the decks remoteit gives you more control if say your driving to work in the morning and dont wanna have your subs going you can just turn them off thanks uhoh im would like to do that so when you dont wont all the bass you can just turn um off Quote Link to comment Share on other sites More sharing options...
Guest mkornely89 Posted January 27, 2009 Report Share Posted January 27, 2009 thats how my 2 amps are set up, no problems Quote Link to comment Share on other sites More sharing options...
uhoh_45 Posted January 27, 2009 Report Share Posted January 27, 2009 also helps if you need to cut your system off say cops or somthing and your beatin your music you have a quick kill switch Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
EarthQuaKeAudio Posted January 27, 2009 Report Share Posted January 27, 2009 [yeah it works, have my 2 sub amps running off a toggle switch and my mids/high amp off the decks remote it gives you more control if say your driving to work in the morning and dont wanna have your subs going you can just turn them off ] yeah i have the same thing, i have a switch right at the kick panel under the foot e-brake.....just incase i cant turn the volume down when i see cops. Quote Link to comment Share on other sites More sharing options...
Boon Posted January 27, 2009 Report Share Posted January 27, 2009 3 is about the limit I would hook up to a single headunit's remote. You don't wanna pull too much current through that little wire and bake your headunit's remote circuit Quote 10.x volts fo' life! Link to comment Share on other sites More sharing options...
