Alt Not Turning On (working Now)
Just wondering if this happened to anybody else. i started my car this morning and my voltage will not go past 11.3 volts. i have a mechman alt and need help.
Edited by kkiiaann33
Club 150 (15x.x)
Youtube
Future Build:
1x 15" T3 TSNS
2x Sundown Audio SAZ3000d Parellel strapped
Does it stay at 11.3 or does is slowly drop as you drive?
Need an install? Hit me up.
[email protected]
Got car audio questions? Check here first!
Everything you need to know. =]
http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
no it just stays @ 11.3 when i drive it's not going up. when i turn my lights on, it goes down to 11.2 then will go back up ot 11.3-.4 after i turn my lights off. right now i think i am running my car straight off my batteries.
Club 150 (15x.x)
Youtube
Future Build:
1x 15" T3 TSNS
yeah i had this happen when i just put mine one, how many wire plug is it for your alt
TEAM NEMESIS
my system
1) us amps MD3D, us amps md21
2) kicker solo x 12 in 2.7ft^3 at 37hz
Meca scores
1 xxx12" 141.8db at 40hz,
1 18 rd alpha v.2 145 db at 38hz , 2 12 orion hp 144.9 at 43hz
Refs: hollatchaboy, schrummy, nitro_freak1,Brandon15zzz,Hellbound Train
ok well check the other two with a dmm on both sides of the plug and make sure you are getting a switch voltage, and you will also have a constant voltage wire. the thicker one should be constant and the other switch. that was my problem the plug corroded and no voltage could get through to turn the alt on. and mechman said that over time some plugs will do this.
TEAM NEMESIS
my system
Meca scores
You my friend deserve a cookie. it turn on. when i hard wired a 12 volt wire to the on/off switch plug. So what i'm going to do is have my alt running off of my accessory . line so when my car turns on the alt will turn on. THANK YOU.
Club 150 (15x.x)
Youtube
Future Build:
1x 15" T3 TSNS
  • Who's Online   0 Members, 0 Anonymous, 1624 Guests (See full list)
