I have 12K HID kit for my truck had it for some time now but the problem is
when i turn the lights on they fire up and warm up to full brightness then
when my deck and amp ect. turn on my lights dim down, also i have the hi/lo beam
hid bulb and only my lo beams work? everything is connected properly im thinking its my battery
thats too weak?
98 Dodge Durango
12 000K 50/55W Headlights
12 000K 35W Fog lights
HU Panasonic CQ-VX100 7" Reciever
(1) Fi SSD 18" Fully Loaded
(1) Ported box 33hz
(1) Soundstream TRX1500D
(1) Soundstream TRX2.440
(1) RE 6.5" Component Set
(1) Rear battery
Big 3 in 0/1 gauge
2 runs of 1/0 Gauge wire
250A Alt soon..
bump
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
Or your alt cant keep up
Baylor University
Accounting
do you have the plug and play kind? b/c some need a wiring relay that connects to the battery, some dont come with this unless you order it seperatly.
If I'm right most HID's use lower wattage than normal halogens. IMO its either the wiring or the relay/problem with it.
Derp.
its just a plug n play with stock wirirng going into the ballasts and its imposible
pretty much to mess up the connections ones female and the other male for the
bulbs. so i dont think its that
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
Then you probobly need the realy to connect them to the battery. At first i didnt get the realy with the kit, and they would be ok a few times and then only one would turn on. turns out i needed the relay, and I havent had a problem after that.
why would i need a relay if the power is already coming from the stock wiring?
im just wondering why they dim after warm up?
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
uhm, im not sure then im outta ideas. U should called the place where u go them from.....hopefully they can help you.
order from japanese HID kit company so
dont think we can talk in same language haha
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
