Setting Subsonic And Lpf
MaX
I have a AQ2200D and at the moment I have no clue where the subsonic and lowpass need to be set at. for the time being both are set at approximately the 12 o'clock position which sounds ok. But I want to be as accurate as possible with this. Any suggestions of where to put them??
<div align='center'>03 RAV4
18" DC Level 4 XL
Knukonceptz 1/0 gauge
AudioQue 2200D
6.25 cubic foot box tuned to 32 hz
DB Linc 200 Amp H/O ALT
1/0 BIG III</div>
The subsonic filter dampens all frequencies below where you set it so as not to unload your subs if you play a frequency below the port tuning. If it's a ported box, set the subsonic about 5hZ below the tuning frequency. If it's sealed, turn the subsonic all the way down to 20.
As far as LPF, it's almost the opposite of a subsonic. It dampens the high frequencies that a sub shouldn't play which is usually above 80hZ. Just set it around 80hZ and that should be good.
This is assuming it's a basic daily system. I'm not going to go in depth, but this is the layman explanation.
PS Don't set it by the clock hand.
Need an install? Hit me up.
[email protected]
Got car audio questions? Check here first!
Everything you need to know. =]
http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
whats your tuning frequency?
well my box is tuned around 30 hz, so i should set my subsonic at about 23-25 hz correct?
and yea, its a daily system
18" DC Level 4 XL
AudioQue 2200D
1/0 BIG III</div>
Yep.
As for LPF, you should set that to around 125 just because it sounds better :) Although, 80 is perfect for most people
Edited by moh.vze.com
Yep.
damn! really
still too high for me, but he might like it idk
60hz & down is for subs technically, if you're crossing over that high a lacking mid-bass may be the culprit.
  • Who's Online   1 Member, 0 Anonymous, 1422 Guests (See full list)
