Battery Tray/build Progress
I'm close to finishing my first system...
Since I can't wait much longer for my dad to help me with the battery tray is there anyone that can help me get with the install.
Pics?
Also I wanted any suggestions on where to mount my amp.
It's a Rockford Fosgate t1000.1bd
Some build pics...
mediocre to say the least but hey its something.
cutting the inner circle.
it is going to be double baffled.
curing the glue.
splitting the remote turn on from bose to RF amps.
and running the RCA.
after being cleaned.
also after I finally got off the last of the plastic trim crap...
flares and running boards.
Wouldnt be thehoe92 without teh purple
Pics?
Some build pics...
curing the glue.
If you want to mount amp, under the back seat is a good place. I have an 01 tahoe, i have a optima yellow top and 2 amps under my back seat. i used a piece of mdf 48 inches long cut it to go around all the seat brackets on wrapped in vinal. You have easy access to it and its out of the way, and all the wiring can go under the mdf, just cut holes to run wiring to amps.
2001 Tahoe
Alpine IVA-W505
2 OPTIMA's RED/YELLOW
DUAL ALTs 140/220
(2) HIFONICS BXI1280D
(1) HIFONICS ZXI6408
(4) ALPINE SPR-13S 5.25
(4) ALPINE SPR-17S 6.5
(2) KICKER 15L7 at 1 ohm 4.5 CUBIC@38HZ
2001 Tahoe
Alpine IVA-W505
DUAL ALTs 140/220
you can fit a second batt in the engine bay, pass side way up by the firewall..
I have an 04 suburban and put a kinetik2000 up there.
can I get a picture of that by any chance because I just put the tray in and I can't fit an HC1400 in without taking out the support.
heres a pic with a kinetik 1800
wrong pic?
thats just the alternator... :unknw:
nevermind you changed it.
so just tilt it and I should be good?
what about strapping it down?
my bad my laptop is slow but i fixed it.
if u look close there is a screw on the bracket with a rubber tip holding the battery down.
and the bracket was lifted up to go over the battery. where the bracket and fender bolt up
i took my support out.
as far as a strap, I built a tray that holds it in place..
a 14 or 1800 might bounce around, but trust me a 2000 is so tight its not going anywhere
  • Who's Online   0 Members, 0 Anonymous, 887 Guests (See full list)
