i wasn't sure which monoblock. now i know the kicker ZX2500.1 is the one i want. about how much power will it be giving to each?
1994 Ford F150 reg cab
2 HFX 12's
Audiopipe APSM-1300
Between 625 (minimum rated) and 700 watts per woofer.
Each amp is a little different, it will come with a birthsheet which confirms it actually does 2500+
2001 Chevy Blazer
(2) SAZ-3000Ds
(2) custom 18" Madmax subs in a second row wall
Rockford 600-4
Pioneer PRS components
Pioneer P800PRS deck
my price range is high. probably $2000 for an amp. but i'm just going to go with the kicker. it sounds like it'll provide enough power to the 4 15"s. thanks everyone.
2 HFX 12's
Audiopipe APSM-1300
4000 at 2 ohms? jesus. lol. i don't wanna kill the things. i just want to have them have close to their max. but thanks for the idea.
you dont always have to push things to their max to get your moneys worth.
If you've been doing something for 20 years, does that mean what you do it right???
__________________________________
Want:
2x Phoenix Gold RSD65CS
Comp Amp Undecided
AA Havoc
AQ 1200
knu wiring
set scew lugs for all connections
Alpine IDA-X303 2v preout :(--this goes under the seat.
Have:
Alpine tape deck w/ Benzi Box and 6 disc changer
Check out my Toyota build
So the Kicker ZX2500.1 isn't a monoblock? lol
News to me.
Cause that's what I said right? :01nocomment8so:
I know nothing about car audio. Don't listen to me.
Need an install? Hit me up.
[email protected]
Sadly it looks that way, no offense. :unsure:
"Monoblock" simply means 1 channel, as opposed to a stereo amplifier. A monoblock amp can be 1-ohm stable, 2-ohm stable, 8-ohm stable, etc etc... "Mono" merely makes reference to the number of channels, or 1, and has NO bearing whatsoever on the minimum ohm load the amp is stable to.
Just trying to help keep the misinformation at a minimum. :) I know all this stuff can be confusing enough for people just getting into the hobby, throwing questionable terminology around doesn't help anyone. Please don't take it personally, I'm just trying to help.
2001 Chevy Blazer
(2) SAZ-3000Ds
Rockford 600-4
More than likely if you buy a 3000W @ 1-ohm monoblock, you'll only be getting 1500 out of it because your final load will be 2-ohms and your subs will only be getting ~375W a piece. It's not the best idea.
Edit:
This guy clearly does know what he's talking about! :pardon:
(I just checked out some of his builds, very nice :) )
Miscommunication strikes again. I added the word in boldface which would have originally solved everything.
Cheers!
Edited by creyc
2001 Chevy Blazer
(2) SAZ-3000Ds
Rockford 600-4
Edit:
Cheers!
yea. i'm not good at amps so i wasn't sure. but i deff don't want my subs only getting around 350 or so. i want ATLEAST 600W. which i am hoping to achieve using the kicker ZX2500.1
2 HFX 12's
Audiopipe APSM-1300
